I have Zorin OS Pro.
I have startup application that I want to start. I want to bind them to start on my 2nd monitor. Instead of me shifting it to Monitor 1.
- Spotify
- Discord
- Steam
APPS are designed by default to open on the monitor that is set as primarily.
So whichever display is set as Primary, that is what APPS will default to load to. So, if you don't like how it is now, consider switching your other display as PRIMARY.
The only other way I can think of, is to manually shift them over, the thing you don't want to do.
