I have been using CCleaner on Windows and Bleachbit on Linux for several years without any issue. Yet, time to time, I encounter quite negative comments on those so-called system optimizers. Seeing that Bleachbit can be installed in Software in Zorin, it cannot be that dangerous.
I'd like to hear from other Zorin users about their opinion regarding pros and cons of system optimizers such as Bleachbit.
Thanks for this tip @Storm
Just found this Stacer review article at OMG Ubuntu
It looks gorgeous I like its looks over the Bleachbit.
I will install it on my testing laptop first and if all goes well, I will use this instead of Bleachbit.
You might find the following page informative. After I read it I decided to switch to Stacer.
I think the biggest difference is that Stacer is developed on Electron where as Bleachbit is using GTK+3. There are some criticism for Electron apps but it is hard to deny that they are very nice looking
I would say that Bleachbit and Stacer are at about the same level of "safe" as long as a person Reads and Follows the directions.
Personally, I find the placebo effect is stronger than the results. Ever run the cleaner and it displays the long list of cleaning and finally yields 142 kbs of freed space?
Impressive.
Really, sudo apt clean and sudo apt autoremove are most of what you need. Many may prefer to clean out Trash and Thumbnails on occasion; both of which are in ~/.local/share so no root needed.
Personally, I use ubuntu-cleaner (If I am in a hurry) because it hits those basics without all the fluff and pomp. Running Ubuntu Cleaner does what I just said: Cleans out the thumbnail cache, apt-clean, removes installed package configs. All you need, really.
Preferences matter. Stacer comes with some good charts and graphs and such; but to me it is not a selling point since my conky's display all that stuff 24/7.
I remember i used bleachbit before. Are you seriously this isn't good software?
If this isn't safety then what is your opinion to use another software in Linux?
then bleachbit is more safety if you in terminal could delete some files what could be unstable Zorin. Now I understand. I used before bleachbit on another platforms.
Bleachbit has an autoremove and cleaning options which can be run from the the terminal also. Problems can occur when 3rd party software such as PPA's share dependencies from removed applications, the result being a broken package system. Users who install more than one desktop environment should be cautious of this as well.
