i installed Zorin OS 17 core on my alienware-17 . the bluetooth doesn't work normaly and zorin connect too . and i think CPU driver is not installed . + i wont to remove power save and get the advance option
Can you please post the terminal output for
sudo lshw -C network
*-network
product: Killer E220x Gigabit Ethernet Controller
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:08:00.0
logical name: enp8s0
version: 10
serial: f0:1f:af:43:d1:31
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=alx driverversion=6.2.0-39-generic latency=0 link=no multicast=yes port=twisted pair
resources: irq:18 memory:d2800000-d283ffff ioport:3000(size=128)
*-network
product: BCM4352 802.11ac Wireless Network Adapter
vendor: Broadcom Inc. and subsidiaries
physical id: 0
bus info: pci@0000:0a:00.0
logical name: wlp10s0
version: 03
serial: 24:0a:64:b7:d1:50
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=wl0 driverversion=6.30.223.271 (r587334) ip=192.168.1.7 latency=0 multicast=yes wireless=IEEE 802.11
resources: irq:16 memory:d2600000-d2607fff memory:d2400000-d25fffff
See if this Bluetooth guide for fixing issues on ubuntu 22.04 helps which is what Zorin 17 is based upon:
In respect of the Power issue - this answer on askubuntu might shed some light:
