Bluetooth Dead
Zorin 17.2 on Lenovo T420. Bluetooth not working. The bluetooth icon doesn't light. Have Blueman but that doesn't show anything.
Here is the output of the following commands.
$ systemctl start bluetooth (no output)
$ sudo /etc/init.d/bluetooth status
○ bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: inactive (dead)
Docs: man:bluetoothd(8)
Oct 09 09:10:08 stephen-ThinkPad-T420 systemd[1]: Condition check resulted in Bluetooth service being skipped.
Oct 09 09:11:41 stephen-ThinkPad-T420 systemd[1]: Condition check resulted in Bluetooth service being skipped.
Oct 09 09:21:18 stephen-ThinkPad-T420 systemd[1]: Condition check resulted in Bluetooth service being skipped.
sudo lshw -C network
*-network
product: 82579LM Gigabit Network Connection (Lewisville)
vendor: Intel Corporation
physical id: 19
bus info: pci@0000:00:19.0
logical name: enp0s25
version: 04
serial: 00:21:cc:bd:89:6e
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=6.8.0-45-generic firmware=0.13-3 latency=0 link=no multicast=yes port=twisted pair
resources: irq:27 memory:f3900000-f391ffff memory:f392b000-f392bfff ioport:6080(size=32)
*-network
product: Centrino Wireless-N 1000 [Condor Peak]
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: 00
serial: 74:e5:0b:e7:75:e6
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=6.8.0-45-generic firmware=39.31.5.1 build 35138 1000-5.uc ip=192.168.1.246 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:32 memory:f3800000-f3801fff
Thanks for any pointers.
See if this helps:
Did You checked if it is deactivated in the BIOS?
Yes checked Bios. It's activated.
Check please in /etc/bluetooth/main.conf the last Line AutoEnable. Does there stand false or true?
Sorry for the late reply. Thanks for answering. The file you asked about states 'Autoenable=true'
Did You take a Look in the ''Additional Drivers'' Tab in Software & Updates if there are any Drivers offered?
