The bluetooth actually works fine but then suddenly it stops working and doesn't connects my audio devices or nothing I can say. Like the bluetooth is on but when I connect something, it just shows me this:
Please tell me the solution regarding this...
Please open a terminal and run
sudo apt install pulseaudio-module-bluetooth
pactl load-module module-bluetooth-discover
Then test Bluetooth...
Please run:
sudo apt install --reinstall linux-headers-5.15.0-84-generic linux-image-5.15.0-84-generic linux-modules-5.15.0-84-generic linux-modules-extra-5.15.0-84-generic
Reboot, then try running
again...
Can you please install blueman
sudo apt install blueman
Launch blueman
Click Setup
See if you can configure bluetooth using the blueman-manager...
actually bluetooth works well, the bluetooth suddenly does not work and that time, when I launch blueman, the application hangs as well as settings app
