Hello I followed your instruction but when I want to close files it said I don't have permission to save changes to the files , and I entered command to terminal it said I am in root "mode"
Hi and welcome to the forum
Since you are necromancing
3 month old thread in non-English language,
I will create a new thread for you.
Here we are.
This thread is all yours.
Please describe the problem you have with your Bluetooth along with which version of Zorin you are using.
Hello. I am using Zorin OS 16 core.So issue that I have is that my Bluetooth mouse when is connected works some time than stop, when I want to disable and enable Bluetooth interface will not enable Bluetooth again. I tried to do what Aravish suggested in terminal to type command sudo -i and than change lines in 2 files: /etc / NetworkManager/conf.d/default-wifi-powersave-on.conf
wifi.powersave = 3change to
wifi.powersave = 2 and remove hashtag in following/etc/bluetooth/input.conf #UserspaceHID=true
,UserspaceHID=true
but when I want to close and save changes I got message I am not allowed to make changes
Hello Vlad, try it with;
sudo nano {path to file}
on both files
After adjusting the line use CTRL + x and then y
when you say path to the file you mine to type this in terminal after sudo-I? I am new to linux , so my questoin is maybe stupid
Yes, but it's
sudo nano /etc.....
for both files.
Your doing alright there, but I believe this is not the right file, because the values you are suppose to mutate are missing. Close it (Ctrl +x and n).
Try again but use the full right path which is given by Aravisian,
sudo nano /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
it should lead to this output with the values present;
got it , I am in and now I just delete 3 and punch 2? how to save changes now and exit?
I described it above; CTRL + x then y.
Fixed
It's ok , but I believe it would be read-only then, but I might be wrong.
same thing again works for a while and stop working, and when I go to bluetooth options it shows as mouse connected and when I want to disconnected will not allow and move back slide as connected same thing for headphones
cat /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
this is the respond I get when I type this in terminal: [connection]
wifi.powersave = 2
Can you please note all devices mac addresses.
Then, disconnect all Blue devices.
Run
bluetoothctl
You will see a couple of prompts. First
agent on
Then,
default agent
Using your Mac addresses for your devices
devices
Replace PLACEHOLDER with the mac address of the device
trust PLACEHOLDER
pair PLACEHOLDER
connect PLACEHOLDER
same thing worked for a while and stop working, shows mouse is connected in bluetooth setings
