Bluetooth Menu In Quick Settings
Hello,
New to the forum and not sure where to place feature requests. I really like Zorin 17 Pro - been very smooth and stable. Just a quick request, would it be possible to add a submenu for bluetooth devices in the quick menu similar to wifi networks with the '-->' icon? See attached photo.
I recommend you contact the GNOME foundation and submit that there as well. It is possible the two developers, both brothers, can do that but they usually just tweak the existing GNOME desktop to their vision. They don’t do that much but they do a few things with their own extensions or other off the shelf extensions but it is not that much versus default GNOME.
https://foundation.gnome.org/
Try this extension:
https://extensions.gnome.org/extension/1401/bluetooth-quick-connect/
