Hi, I am new here but the bluetooth is not showing all devices and cannot manage to connect. How to fix this issue? thank you!
Do you have Blueman Manager installed? If not:
sudo apt install blueman
Launch the Blueman manager using app menu,. alt+F2 and entering in blueman-manager or terminal by entering in blueman-manager
With that launched, ensure the device is set to pairing - then click Scan in the manager.
Does Your bluetooth in common work? Did You checked the ''Additional Drivers'' Tab in Software & Updates if there is a Driver offered? Is it only one specific Device what doesn't work or several? Could You post the Ouput of the Command rfkill list please?
