I've been using Zorin OS for a little over two months now, but I have a recurrent problem with my Bluetooth connections.
At first, everything seems to connect fine, but after a while (around two hours) the connections are lost and my pc doesn't find any bluetooth devices around. This happens with my Logitech M196 mouse and my headphones, and whenever I test other bluetooth signals, the laptop can't find them either (my phone, for example), even if I scan using the terminal or using rfkill.
It's very annoying and I'm even considering changing distros or going back to Windows because of that. It's been two months so I have already tried every single solution on this forum, youtube and Reddit.
I do use blueman to manage bluetooth connections and log using Xorg instead of Wayland, the issue persists.
Whenever this happens, I have to restart my laptop a few times for it to start recognizing my devices. I even changed my headphone for a wired one to work around this issue, but - honestly - I refuse to do the same with my mouse.
Do You use built-in Bluetooth from Your PC/Laptop/Mainboard or do You use a Dongle? Did You checked the ''Additional Drivers'' Tab if there is a Driver offered?
I had already tried modprobe before and it didn't work, but I gave it another try today just in case. The bluetooth randomly disconnected my mouse a few minutes ago and now it can't find either the mouse or any other devices nearby.
Also, when I check from my phone, the PC itself isn't visible, even though it is set to be discoverable.
I used Ubuntu 24.04 in my search criteria as Zorin 18 is a fork of same.
Brave A.I. search via Mojeek comes back with:
" Bluetooth connectivity issues on Ubuntu 24.04 with the RTL8852BE chipset are commonly caused by power management conflicts between the kernel driver and the hardware, or firmware mismatches following system upgrades.
Primary Solutions
Disable ASPM and Power Saving: The most effective fix for the RTL8852BE is to disable Active State Power Management (ASPM) for the rtw89 driver. Create or edit the file /etc/modprobe.d/70-rtw89.conf and add the following lines:
Update Bluetooth Firmware: If the issue started after upgrading to Ubuntu 24.04.2 or later, the default firmware may be outdated. Manually download the correct firmware by running:
cd /lib/firmware/rtl_bt && sudo wget https://raw.githubusercontent.com/linuxfirmware/rtl_bt/main/rtl8852bu_fw.bin
(Note: Some users report success with rtl8852bu_fw.bin despite the BE chipset, as the driver often shares components). Reboot after downloading.
Kernel Version Check: Recent kernel updates (e.g., 6.17.x) have introduced regressions. If the issue persists, try booting into an older kernel (e.g., 6.8.0 or 6.14) via the GRUB menu's "Advanced Options" to see if stability returns.
Hard Reset: In some cases, residual power causes the Bluetooth radio to fail to initialize. Perform a hard reset by shutting down , unplugging the power cord, holding the power button for 30 seconds, and then booting.
Once the power management mode is set, you must reboot and test.
Changing the setting does not, in that moment, undo all power throttling. It applies to next time...
I am watching this discussion with interest. Before my recent trip I purchased a Logitech M196 mouse, to use with my Dell 13" notebook, but could not make it work consistently. In a hurry I bought a cheap WiFi mouse which now occupies the only USB 'A' outlet on the notebook. I wonder if it is a problem with the M196?
