I Have two device Sound Output is OK after install driver https://mpow.s3-us-west-1.amazonaws.com/20201202_mpow_BH456A_driver+for+Linux.7z
but the Input sound not working
Hi,
Check if it's muted or volume is set low in Pulseaudio.
sudo apt install pavucontrol
Try with;
alsamixer
and see if you can find it there.
As Storm mentions open Alsamixer in terminal.
Have a look at inputs and see if any are showing "M" muted.
Also have a play (i.e. experiment) with the "Automute" and also "Loopback" settings.
From my personal experience, sound settings do not always follow normal logic so you may have to try a few different things and see what happens.
Another thing that may be contributing could be Bluetooth itself. There are a few threads on here complaining about mic not working on their bluetooth headsets, but no real solution.
I don't know what version or flavour of ZorinOS you are using, but you could maybe try Z16 Core Beta, which may provide better support for latest devices.
