Well when I started back up it worked fine ..... thank you Mr. Wizard ..... do you remember that show or was it before your time ..... if I have a problem I'll be back ..... now to attack the keyboard problem as it disconnected as I was typing this reply .... but at least I'm on the internet now .....
I was a little kid at that time...
Well it has reared it's ugly head again .... the first day it worked fine ..... second day it was off but when I restarted it came back on ..... yesterday it was fine today it was off again .... (BlueTooth keyboard needs to be restarted every day still)
So this morning I followed the steps in the posts above and deleted the driver and reinstalled but got a whole bunch of (W's) so I copied the Terminal text and I also went to Software & Updates and scanned the Other Software but I don't see anything wrong but then I don't know what I'm looking for so I pasted that here also ..... as of right now it is again working after I restarted the laptop .....
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo apt remove --purge r8168-dkms
[sudo] password for mike:
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
r8168-dkms*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 1,388 kB disk space will be freed.
(Reading database ... 352239 files and directories currently installed.)
Removing r8168-dkms (8.048.00-1ubuntu0.20.04.2) ...
-------- Uninstall Beginning --------
Module: r8168
Version: 8.048.00
Kernel: 5.13.0-44-generic (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
r8168.ko:
- Uninstallation
- Deleting from: /lib/modules/5.13.0-44-generic/updates/dkms/
- Original module
- No original module was found for this module on this kernel.
- Use the dkms install command to reinstall any previous mod
ule version.
depmod.........
update-initramfs............
DKMS: uninstall completed.
Deleting module version: 8.048.00
completely from the DKMS tree.
Done.
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.136ubuntu6.7) ...
update-initramfs: Generating /boot/initrd.img-5.13.0-44-generic
I: The initramfs will attempt to resume from /dev/sda2
I: (UUID=19dfc62f-f5fd-4b23-9656-9f8d1c23b6fb)
I: Set the RESUME variable to override this.
(Reading database ... 352219 files and directories currently in
stalled.)
Purging configuration files for r8168-dkms (8.048.00-1ubuntu0.2
0.04.2) ...
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo apt update && sudo apt install r8168-dkms
Err:1 Index of /ubuntu focal InRelease
Temporary failure resolving 'archive.ubuntu.com'
Err:2 Index of /stable/deb/ stable InRelease
Temporary failure resolving 'repo.vivaldi.com'
Err:3 Index of /ubuntu/20.04/prod/ focal InRelease
Temporary failure resolving 'packages.microsoft.com'
Err:4 Index of /deb/nordvpn/debian/ stable InRelease
Temporary failure resolving 'repo.nordvpn.com'
Err:5 Index of /aravisian/gtk-theming/ubuntu focal InRelease
Temporary failure resolving 'ppa.launchpad.net'
Err:6 http://deb.fdmpkg.org bionic InRelease
Temporary failure resolving 'deb.fdmpkg.org'
Err:7 Index of /stable/ focal InRelease
Temporary failure resolving 'packages.zorinos.com'
Err:8 Index of /ubuntu focal-updates InRelease
Err:9 Index of /aravisian/iconsets/ubuntu focal InRelease
Err:10 Index of /patches/ focal InRelease
Err:11 Index of /ubuntu focal-backports InRelease
Err:12 Index of /gerardpuig/ppa/ubuntu focal InRelease
Err:13 Index of /apps/ focal InRelease
Err:14 Index of /ubuntu focal-security InRelease
Err:15 Index of /gezakovacs/ppa/ubuntu focal InRelease
Err:16 Index of /drivers/ focal InRelease
Err:17 Index of /lutris-team/lutris/ubuntu focal InRelease
Err:18 Download - Zorin OS focal InRelease
Err:19 Index of /zorinos/apps/ubuntu focal InRelease
Err:20 Index of /zorinos/drivers/ubuntu focal InRelease
Err:21 Index of /zorinos/patches/ubuntu focal InRelease
Err:22 Index of /zorinos/stable/ubuntu focal InRelease
All packages are up to date.
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/InRelease Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-backports/InRelease Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-security/InRelease Temporary failure resolving 'archive.ubuntu.com'
W: Failed to fetch http://ppa.launchpad.net/aravisian/gtk-theming/ubuntu/dists/focal/InRelease Temporary failure resolving 'ppa.launchpad.net'
W: Failed to fetch http://ppa.launchpad.net/aravisian/iconsets/ubuntu/dists/focal/InRelease Temporary failure resolving 'ppa.launchpad.net'
W: Failed to fetch http://deb.fdmpkg.org/dists/bionic/InRelease Temporary failure resolving 'deb.fdmpkg.org'
W: Failed to fetch http://ppa.launchpad.net/gerardpuig/ppa/ubuntu/dists/focal/InRelease Temporary failure resolving 'ppa.launchpad.net'
W: Failed to fetch http://ppa.launchpad.net/gezakovacs/ppa/ubuntu/dists/focal/InRelease Temporary failure resolving 'ppa.launchpad.net'
W: Failed to fetch http://ppa.launchpad.net/lutris-team/lutris/ubuntu/dists/focal/InRelease Temporary failure resolving 'ppa.launchpad.net'
W: Failed to fetch https://packages.microsoft.com/ubuntu/20.04/prod/dists/focal/InRelease Temporary failure resolving 'packages.microsoft.com'
W: Failed to fetch https://repo.nordvpn.com/deb/nordvpn/debian/dists/stable/InRelease Temporary failure resolving 'repo.nordvpn.com'
W: Failed to fetch https://repo.vivaldi.com/stable/deb/dists/stable/InRelease Temporary failure resolving 'repo.vivaldi.com'
W: Failed to fetch https://packages.zorinos.com/stable/dists/focal/InRelease Temporary failure resolving 'packages.zorinos.com'
W: Failed to fetch https://packages.zorinos.com/patches/dists/focal/InRelease Temporary failure resolving 'packages.zorinos.com'
W: Failed to fetch https://packages.zorinos.com/apps/dists/focal/InRelease Temporary failure resolving 'packages.zorinos.com'
W: Failed to fetch https://packages.zorinos.com/drivers/dists/focal/InRelease Temporary failure resolving 'packages.zorinos.com'
W: Failed to fetch Download - Zorin OS Temporary failure resolving 'packages.zorinos.com'
W: Failed to fetch http://ppa.launchpad.net/zorinos/apps/ubuntu/dists/focal/InRelease Temporary failure resolving 'ppa.launchpad.net'
W: Failed to fetch http://ppa.launchpad.net/zorinos/drivers/ubuntu/dists/focal/InRelease Temporary failure resolving 'ppa.launchpad.net'
W: Failed to fetch http://ppa.launchpad.net/zorinos/patches/ubuntu/dists/focal/InRelease Temporary failure resolving 'ppa.launchpad.net'
W: Failed to fetch http://ppa.launchpad.net/zorinos/stable/ubuntu/dists/focal/InRelease Temporary failure resolving 'ppa.launchpad.net'
W: Some index files failed to download. They have been ignored, or old ones used instead.
r8168-dkms
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 98.3 kB of archives.
After this operation, 1,388 kB of additional disk space will be used.
Ign:1 Index of /ubuntu focal-updates/universe amd64 r8168-dkms all 8.048.00-1ubuntu0.20.04.2
Err:1 Index of /ubuntu focal-updates/universe amd64 r8168-dkms all 8.048.00-1ubuntu0.20.04.2
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/universe/r/r8168/r8168-dkms_8.048.00-1ubuntu0.20.04.2_all.deb Temporary failure resolving 'archive.ubuntu.com'
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo sh -c 'echo blacklist r8169 >> /etc/modprobe.d/blacklist.conf'
Those errors and warnings indicate lack of internet access to download or check files.
I am starting to wonder if this is a hardware issue.
If the drivers work but slowly the device stops working- the hardware is likely failing.
I was wondering about that also .... a while back I contacted the repair shop that does the Asus warranty service here and they told me that the card was not available any more ... this machine is only 3 years old .... so I went on line to Asus website and found the info on the card .... called them back and gave them the answer .... their reply was for me to bring it in and they would open it up and see ..... I gave them the model and ser. number on my case but they still want to open up the laptop ....
Sorry but I don't have much faith in a business that tells me the card is obsolete and then when I find them the info they say bring it in and they will disassemble it to see .... all I want them to do is order me the card and I will put it in .....
I'm also thinking of opening it up myself and taking out the card and bringing it to them .....
Will the computer still run with the card missing ... except for the WiFi and BlueTooth which only works half the time now .....
Yes, the computer itself should work - but you would have no net.
What about a Wifi Dongle? Might be a viable alternative or at the least - a back up system in case the "obsolete" card gets too problematic to repair...
I have a dongle but the instructions are very poor and I don't know how to open the file .... I have a topic somewhere here on the board about 3-4 months ago .... it was never solved as far as I know ..... I'll see if I can find it ....
I found the link ..... we worked on this problem before .....
I'll be down for a bit as I just installed Zorin 16.1 Lite on my Acer laptop .... my god this is the easiest install ever .... no fuss no muss ..... I allocated 200GB for it a bit over kill I know but rather be safe than sorry I have 800GB left on the drive for Win 7 and games .... I only play 1-2 games at a time and wipe them when I'm done so should be plenty of space .... see ya when I get done .....
Crosslink:
