How to auto switch bluetooth “on” on system startup?
If you want Bluetooth enabled all the time then there is a setting for that.
I don’t know if there is any difference between Core and Lite settings, but this screenshot is from Core.
I thought BT was on by default anyway. I always have to use the settings above to switch it off, when installing Zorin, as I don’t have any BT devices.
In the “Startup Applications” I added sudo bluetooth on
. Now bluetooth automatically switches on upon startup.
