Iam just installed zorin os 18 after as alternative to windows 10
Everything wokrs fine but Bluetooth is keep searching for devices with no results
Did You take a Look in the ''Additional Drivers'' Tab if there is a Driver for Your Bluetooth offered? And what Devices You want connect?
Once you turned on Bluetooth, have you restarted your computer since as well? After you have done that, make sure the other device you are trying to connect, has its bluetooth on, and device has been set to discoverable.
have you updated yet?
Updater not ready yet, so no. I didn't know it was going to take this long. Having said that, im patient, when it comes, ill upgrade.
