So I have USB-BT500 (made by Asus) and they actually gave me Linux installation file, but how do I install? readme file does not helpful
Please open a terminal Within the directory you show in your screenshot. If your file manger supports it, you may be able to Right click and then select "Open in terminal" from the menu.
Otherwise, you will need to cd
command to that path.
In that terminal, try the commands:
make
sudo make install INTERFACE=usb
The above is a guess on my part... without having access to that package... I am not sure if that will work.
That works. When I install, i need to replug my dongle. And now it works. Thanks
