I am not able to boot my os as my I am new to linux I don't know much about linux but I am trying to learn I am stuck on the same screen for hours
If you are not dual booting Windows with Zorin OS, then Secure Boot should be disabled in BIOS Settings.
Secure Boot is for Windows OS only.
I have disable the secured boot already
The things I was setting up the time shift and after some time time shift was giving popup message like there is not enough space after that I shut down the laptop and few hours later when I turned on my laptop I am facing this issue my screen got stuck on the same page every time
How much space does the Root Partition have? What is the size of that partition?
