Hello guys,
I have problem with boot repair app, it keeps saying disable UEFI firmware and I did it several times, It really drives me crazy. By the way I don't have problem booting into OS manually selecting the devices.
The current session is in BIOS-compatibility mode. Please disable BIOS-compatibility/CSM/Legacy mode in your UEFI firmware, and use this software from a live-CD (or live-USB) that is compatible with UEFI booting mode. For example, use a live-USB of Boot-Repair-Disk-64bit (boot-repair-disk download | SourceForge.net), after making sure your BIOS is set up to boot USB in EFI mode. This will enable this feature.
This is saying to go to your BIOS Settings and disable CSM and Legacy Mode. That is what it is saying to do... Though I notice that you also have MBR (legacy) listed on other drives. I am not sure if you are using those, or if you are able to disable Legacy boot if you need it for those drives.
This means that once you have done the above, to re-run the Boot Repair software.
