Bottles menu not showing
Done that - here's the result:
shoshi@shoshi-ThinkPad:~$ sudo apt purge libdecor-0-plugin-1-gtk:i386
[sudo] password for shoshi:
Reading package lists... Done
libatk-bridge2.0-0t64:i386 libatk1.0-0t64:i386 libatspi2.0-0t64:i386
libcolord2:i386 libepoxy0:i386 liblcms2-2:i386
The following packages will be REMOVED
libdecor-0-plugin-1-gtk:i386*
0 to upgrade, 0 to newly install, 1 to remove and 61 not to upgrade.
247 not fully installed or removed.
After this operation, 74.8 kB disk space will be freed.
Do you want to continue? [Y/n]
Ha ha! Bless you - you are both being so kind and helpful spending all this time on me!
<Kind, but prone to typo's. Thanks to @Ponce-De-Leon for spotting and correcting it.
Ah, that looks good. Remove it and then try it again with:
Did that, got this:
shoshi@shoshi-ThinkPad:~$ sudo apt purge zorin-windows-app-support
fonts-wine glib-networking:i386 gstreamer1.0-plugins-base:i386
gstreamer1.0-plugins-good:i386 gstreamer1.0-x:i386 i965-va-driver:i386
intel-media-va-driver:i386 libaa1:i386 libaom3:i386 libapparmor1:i386
libasound2-plugins:i386 libasound2t64:i386 libasyncns0:i386
libatk-bridge2.0-0t64:i386 libatk1.0-0t64:i386 libatomic1:i386
libatspi2.0-0t64:i386 libavahi-client3:i386 libavahi-common-data:i386
libavahi-common3:i386 libavc1394-0:i386 libavcodec60:i386 libavformat60:i386
libavutil58:i386 libbluray2:i386 libbrotli1:i386 libbsd0:i386 libcaca0:i386
libcairo-gobject2:i386 libcairo2:i386 libcapi20-3t64 libcapi20-3t64:i386
libcdparanoia0:i386 libchromaprint1:i386 libcjson1:i386 libcodec2-1.2:i386
libcolord2:i386 libcups2t64:i386 libcurl3t64-gnutls:i386 libcurl4t64:i386
libdatrie1:i386 libdav1d7:i386 libdb5.3t64:i386 libde265-0:i386
libdecor-0-0:i386 libdeflate0:i386 libdrm-amdgpu1:i386 libdrm-intel1:i386
libdrm2:i386 libduktape207:i386 libdv4t64:i386 libdw1t64:i386 libedit2:i386
libegl-mesa0:i386 libegl1:i386 libelf1t64:i386 libepoxy0:i386 libexif12:i386
libexpat1:i386 libffi8:i386 libflac12t64:i386 libfontconfig1:i386
libfreetype6:i386 libfribidi0:i386 libgbm1:i386 libgd3:i386
libgdk-pixbuf-2.0-0:i386 libgl1:i386 libgl1-mesa-dri:i386
libglib2.0-0t64:i386 libglvnd0:i386 libglx-mesa0:i386 libglx0:i386
libgme0:i386 libgnutls30t64:i386 libgomp1:i386 libgphoto2-6t64:i386
libgphoto2-port12t64:i386 libgraphite2-3:i386 libgsm1:i386
libgssapi-krb5-2:i386 libgstreamer-plugins-base1.0-0:i386
libgstreamer-plugins-good1.0-0:i386 libgstreamer1.0-0:i386
libgudev-1.0-0:i386 libharfbuzz0b:i386 libheif-plugin-aomdec:i386
libheif-plugin-aomenc:i386 libheif-plugin-libde265:i386 libheif1:i386
libhogweed6t64:i386 libicu74:i386 libiec61883-0:i386 libigdgmm12:i386
libjack-jackd2-0:i386 libjbig0:i386 libjpeg-turbo8:i386 libjpeg8:i386
libk5crypto3:i386 libkeyutils1:i386 libkrb5-3:i386 libkrb5support0:i386
liblcms2-2:i386 libldap2:i386 libllvm20:i386 libltdl7:i386
libmbedcrypto7t64:i386 libmp3lame0:i386 libmpg123-0t64:i386 libncurses6:i386
libnettle8t64:i386 libnghttp2-14:i386 libnorm1t64:i386 libnuma1:i386
libodbc2 libodbc2:i386 libogg0:i386 libopenjp2-7:i386 libopenmpt0t64:i386
libopus0:i386 liborc-0.4-0t64:i386 libosmesa6 libosmesa6:i386
libp11-kit0:i386 libpango-1.0-0:i386 libpangocairo-1.0-0:i386
libpangoft2-1.0-0:i386 libpcap0.8t64:i386 libpciaccess0:i386
libpcsclite1:i386 libpgm-5.3-0t64:i386 libpixman-1-0:i386
libpng16-16t64:i386 libproxy1v5:i386 libpsl5t64:i386 libpulse0:i386
librabbitmq4:i386 libraw1394-11:i386 librist4:i386 librsvg2-2:i386
librsvg2-common:i386 librtmp1:i386 libsamplerate0:i386 libsasl2-2:i386
libsasl2-modules:i386 libsasl2-modules-db:i386 libsdl2-2.0-0:i386
libsensors5:i386 libsharpyuv0:i386 libshine3:i386 libshout3:i386
libslang2:i386 libsnappy1v5:i386 libsndfile1:i386 libsodium23:i386
libsoup-3.0-0:i386 libsoxr0:i386 libspeex1:i386 libspeexdsp1:i386
libsqlite3-0:i386 libsrt1.5-gnutls:i386 libssh-4:i386 libssh-gcrypt-4:i386
libstdc++6:i386 libsvtav1enc1d1:i386 libswresample4:i386 libtag1v5:i386
libtag1v5-vanilla:i386 libtasn1-6:i386 libthai0:i386 libtheora0:i386
libtiff6:i386 libtwolame0:i386 libudfread0:i386 libunwind8:i386
libusb-1.0-0:i386 libv4l-0t64:i386 libv4lconvert0t64:i386 libva-drm2:i386
libva-x11-2:i386 libva2:i386 libvdpau1:i386 libvisual-0.4-0:i386
libvorbis0a:i386 libvorbisenc2:i386 libvorbisfile3:i386 libvpx9:i386
libvulkan1:i386 libwavpack1:i386 libwayland-client0:i386
libwayland-cursor0:i386 libwayland-egl1:i386 libwayland-server0:i386
libwebp7:i386 libwebpmux3:i386 libwine libwine:i386 libx11-6:i386
libx11-xcb1:i386 libx264-164:i386 libx265-199:i386 libxau6:i386
libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386 libxcb-randr0:i386
libxcb-render0:i386 libxcb-shm0:i386 libxcb-sync1:i386 libxcb-xfixes0:i386
libxcb1:i386 libxcomposite1:i386 libxcursor1:i386 libxdamage1:i386
libxdmcp6:i386 libxext6:i386 libxfixes3:i386 libxi6:i386 libxinerama1:i386
libxkbcommon0:i386 libxkbregistry0:i386 libxml2:i386 libxpm4:i386
libxrandr2:i386 libxrender1:i386 libxshmfence1:i386 libxss1:i386
libxtst6:i386 libxv1:i386 libxvidcore4:i386 libxxf86vm1:i386 libz-mingw-w64
libzmq5:i386 libzvbi0t64:i386 mesa-libgallium:i386 mesa-va-drivers:i386
mesa-vdpau-drivers:i386 mesa-vulkan-drivers:i386 ocl-icd-libopencl1:i386
va-driver-all:i386 vdpau-driver-all:i386 wine wine32:i386 wine64
zorin-windows-app-support-desktop-files
zorin-windows-app-support*
After this operation, 10.2 kB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 255342 files and directories currently installed.)
Removing zorin-windows-app-support (2.0.3) ...
Has it gone?
That looks good. The Packages are Rests who are not deleted. When I see that right, it should give a Problem when You delete them with sudo apt autoremove but maybe wait for a 2nd Opinion on that.
Are you saying that I should put "sudo apt autoremove"? I am not sure if the problem has been resolved or not. What problem would happen if I do "sudo apt autoremove"? Sorry I don't understand.
sudo apt autoremove would delete all this:
This shouldn't be a Problem but to be sure, it is good to have 2 Pairs of Eyes who look at it.
And with that, WINE should be gone from Your System or do You see any WINE Entries somewhere?
Second pair of eyes - that is safe to remove.
Thank you - it looks as if it's gone - a lot got removed.
How do I check that all Wine has gone off the computer?
In terminal, you can run
wine --version
If you see a version listed, it is installed.
If no output, it is not installed.
That's great. I tried it and got:
Command 'wine' not found, but can be installed with:
sudo apt install wine
The instructions to install it are the first option Ponce-De-Leon suggested earlier in this thread, so I'm going to do that now.
It all seemed to go in OK until the end, when I got:
/tmp/apt-dpkg-install-pAjXjQ/197-libgtk-3-0t64_3.24.41-4ubuntu1.3_i386.deb
Yeah, this has become a current known WINE problem.
Please run:
sudo apt remove libdecor-0-plugin-1-gtk:i386
Then run
sudo apt --fix-broken install
If that does not complete the Wine install, please say so here.
I got this:
libatk-bridge2.0-0t64:i386 libatk1.0-0t64:i386 libatspi2.0-0t64:i386 libcolord2:i386 libepoxy0:i386
liblcms2-2:i386
0 to upgrade, 0 to newly install, 0 to remove and 61 not to upgrade.
Looking good.
Let's cleanup a bit:
That's looking great! Thank you. Now all I've got to do is learn how to install some Windows programs and hope it works this time.
BTW, I was looking online and came across an excellent site called LinuxSimply which has a great glossary of terms with links to take you to articles on each one - I think this is going to be very helpful for a newbie like me especially if I want to learn how to understand and use the Terminal.
You two guys have been so helpful and I really appreciate the time and trouble you've taken over this as I was at my wits' end! I'd like to keep the thread open in case I encounter any further problems getting up and running with Wine if that's OK?
If you come across a separate issue, it is better to start a new thread where solutions uncovered that help others can be easily found.
Different issues can have different solutions.
OK - will do. Again, thank you sooo much for all your help!!
