Brightness goes down when plugged in charger
My battery was low, so I decided to charge. When I plugged in, my screen brightness goes down, is this normal?
You might try
gsettings set org.gnome.settings-daemon.plugins.power ambient-enabled false
to disable the automatic brightness function.
If that does not do the trick, try turning Display Power Manager off:
xset -dpms
