My desktop here is unable to connect to certain devices on my LAN. One is an ASustor NAS and the other is a Synology NAS. They worked yesterday. I think they worked this morning but they don't work now.
My laptop running Zorin can connect to them. I have installed latest update on both but only the desktop has an issue. The laptop uses wifi and the desktop connects via ethernet. If I turn on wifi on the desktop - I have just noticed I can connect to them.
So something is wrong with the ethernet, can anyone suggest what to try next?
Coincidentally I factory reset my router today and changed my LAN IP addressing scheme and all the wifi settings. I thought I had done something wrong there but it looks like its all fine and it was the update that broke it.
EDIT:
I cannot browse to them using SMB/CIFS or connect to their web interfaces, I can ping them okay. Internet browsing also works fine otherwise. Transmission Remote GUI is unable to connect too, that isn't fixed on wifi.
I use gigolo to handle mounting the SMB shares on my LAN and then I use Nemo as my file manager. I have other networked drives that I can connect to so I don't even understand whats going on.
Seeing as its only ethernet where they fail to connect I thought there might be some misconfiguration when I changed the settings. This same PC when I boot into Windows 11 has no issues with the new LAN settings. Everything works. So i'm kind of at a loss as to what to do.
If I wasn't using gigolo then that link might help @swarfendor437 but I used gigolo bacause I couldn't get fstab mounts to work properly in the past.
Then I tried again on the 3rd option and it was all working. Then I tried the first option again and now it was working. Then I've went through the normal Zorin on the first page of grub and now its somehow working again. I didn't do anything other then reboot.
Can anyone explain to me what happened or why it's now fixed seemingly like magic!
EDIT:
Still getting browsing issues with web interfaces but that's probably a separate issue.
UPDATE:
The browsing issue is all fixed. Reverted to windows for now. All working again there. I think. This second issue was related to the different bindings setup for the old network addresses once I changed them to the new IP range the other bits started to work again. Its late here I'll try Zorin again tomorrow.
