As many of you know I have been having problems with my Brother Printer operations for more than a year ..... nothing seemed to work or at least not permanently and I would have to go back to Win 10 to do all my printing ....
I've tried so many different cures and suggestions I have lost track of them so I finally just gave up and used Win 10 which has always worked .....
My biggest problem is I have always had to use CUPS to configure my printer .... except one time when I believe swarf showed me a way to use a different printers driver .... which worked for a while and then I started having problems again ....
So for the past 3 days I have been going on YouTube to see what others have done to make Brothers work on Ubuntu ..... I found 6 different videos all showing about the same way to get it to print .....
I then remembered that in the very beginning I had tried to use the Zorin Brothers approach to installing a Brother Printer which these 6 videos show almost the exact same thing ..... so I went back and copied the Zorin Brothers instructions and tried it again ..... first installing the Installation Driver from the Brother Website for my machine ....
After a bunch of mistakes in the terminal ..... which is where you have to install it from I finally got the driver to install ..... fairly long installation sequence in the terminal ..... I came to the very last step .... choosing my UFI ..... which I copied from the UFI listed in the CUPS Property Settings ..... and that UFI was wrong ....
Now I'm totally beside myself thinking I have to do this terminal thing all over again ..... the instructions also say to restart your computer again after you installed the driver so in total disgust I shut my computer down and took a break ....
Here is the funny part I fired back up and a printer icon appeared in my taskbar so I went to System Settings and opened my printer settings .... there were now 2 printers listed there where before there were none ..... now remember I had made no changes to the terminal commands after they said the program failed ....
The first printer listed had what looked like the correct name that was on the driver folder in Downloads so I chose that one and did a test print ...... OMG it worked ..... so I chose that one as my default printer and disabled the 2nd ..... tested the printer and it worked again .....
If anyone is interested here are a couple of photos of first the error from the terminal and the rest of my new printer settings ......
Both Printers ..... highlighted one is now default .....
Default printer Settings
Second printer note the URI that the terminal said was not valid .....
Not to see if it will remain as my default printer and WORK ...... I am going to do a Rescuezilla back-up to insure that this will hopefully end my printing problems .....
