I could use some help trying to find out why my CSS files are not linking with my HTML files when opening from a mounted drive, only on Zorin17.
I am running a system with two SSDs (one for Windows, one for Linux) and a shared HDD for both of them to access. I recently upgraded from Windows 10 to Windows 11, and from ZorinOS Pro 16 to ZorinOS Pro 17. Ever since then, on only Zorin 17, when I open a .html file that is hosted on a mounted drive in a web browser (any web browser - Firefox, Brave, GNOME Web), it behaves as if it is isolated and cannot link to the CSS file. If I move these files to the SSD where Zorin17 is installed, they also open fine. The problem is only with ZorinOS 17 linking the files on the mounted drive.
Kernel: 6.5.0-14-generic #14~22.04.1-Ubuntu
The mounted drives are NTFS, which is where I assume the problem is coming into play. But I can read/edit/delete files just fine from Zorin17, just can't get the HTML/CSS to link anymore, like they did on Zorin16.
I verified ntfs-3g was installed.
As mentioned, I tried 3 different browsers, including GNOME Web which was freshly installed.
I created a test html/css pair and the issue persists there too. (I have in the head of my HTML document. (I have also tried "/style.css", which doesn't work either.))
I verified the file permissions allow anyone to read/write/execute. Also verified uid and gid match the user account I'm using.
The HTML and CSS files are in the same directory.
I tried three different mounted drives, all had the same issue, regardless of whether they are set to automatically mount or only manually.
I verified fast boot was disabled on Windows 11, as I know that sometimes causes issues with files that are accessed from both operating systems when dual-booting.
I tried removing 'noexec' or 'nosuid' from the mount options, then rebooted and re-mounted, but no change there.
I checked 'dmesg | grep ntfs' on Zorin, which gave me no output, so I'm assuming it found no errors.
I ran 'chkdsk /f' for one of the mounted drives from Windows, then rebooted back into ZorinOS afterward, but there was no difference.
