1 day ago my bluetooth is working fine, next day it won't work, anyone know why? It comes up as undetected, upon boot it throws 5 to 6 errors saying it won't accept it, it's built in.
Check the status
sudo systemctl status bluetooth.service
If off, try:
sudo systemctl enable bluetooth.service && sudo systemctl start bluetooth.service
If no good, reinstall
sudo apt install --reinstall bluez
The run the above command to use systemctl to enable and start the service again.
I followed your steps, it still isn't working, at boot, Zorin OS will say an error of -71 I believe.
Error 71 usually refers to a USB issue.
That points toward a hardware problem.
Do you have any way of testing that dongle on another computer? Or on a LiveUSB of Zorin OS?
This is a very late response, I'm so sorry I suck at keeping up, it's built in, so I can't get rid of the dongle.
If your BT device is built-in, then you could maybe purchase a USB Bluetooth dongle to use instead.
