Built in NFC Reader "NFC Mirage WNC XRAV-1" Support
Hello,
according to this page, my notebook has a built in NFC reader which is called "NFC Mirage WNC XRAV-1"
I want to install an epaclient which says basically right at the beginning, that no card reader was found.
I know the windows variant from that tool works together with that particular reader.
How can I install HW support in Zorin 17.1 for this reader?
Doing some searching I found this:
There also appears to be isssues for Windows users with this device too!:
Dear swarfendor437,
thank you for sharing this two links.
to the 1st one: I currently don't understand how disabling the generic driver should help me, if I don't know where to get the right driver from?
to th 2nd one: I did not had any problems under windows with this device. It just worked out of the box.
Best Regards,
Take a look at this askubuntu thread:
Dear swarfendor437,
thank you for sharing that additional link.
Unfortunately I don't see how that suggested tools should help.
Maybe I did not explain my problem clearly.
I am not looking for tools to read or write nfc tags. I am looking for a way/driver to let my system know I have a NFC reader in the first place.
I thought that what that last link looked at.
Please enter in terminal:
sudo lshw
And post back.
thats quite a long list, though.
maybe this one is more handy?
sudo lshw 1/2
$ sudo lshw
Legen Sie Ihren Finger auf den Fingerabdruckleser
chris-hp-elitebook-845-14-inch-g10-notebook-pc
Beschreibung: Notebook
Produkt: HP EliteBook 845 14 inch G10 Notebook PC (818H6EAR#ABZ)
Hersteller: HP
Version: SBKPF
Seriennummer: 5CG3252LC6
Breite: 64 bits
Fähigkeiten: smbios-3.4.0 dmi-3.4.0 smp vsyscall32
Konfiguration: administrator_password=disabled boot=normal chassis=notebook family=103C_5336AN G=N L=ENT B=HP S=PRO frontpanel_password=disabled keyboard_password=disabled power-on_password=disabled sku=818H6EAR#ABZ uuid=16b6b002-8fa1-4185-a439-18c185c9511f
*-core
Beschreibung: Hauptplatine
Produkt: 8B6E
Hersteller: HP
Physische ID: 0
Version: KBC Version 60.2C.00
Seriennummer: PRWAF00WBIO1EG
*-cache:0
Beschreibung: L1 Cache
Physische ID: 0
Steckplatz: L1 - Cache
Größe: 512KiB
Kapazität: 512KiB
Takt: 1GHz (1.0ns)
Fähigkeiten: pipeline-burst internal write-back unified
Konfiguration: level=1
*-cache:1
Beschreibung: L2 Cache
Physische ID: 1
Steckplatz: L2 - Cache
Größe: 8MiB
Kapazität: 8MiB
Takt: 1GHz (1.0ns)
Konfiguration: level=2
*-cache:2
Beschreibung: L3 Cache
Physische ID: 2
Steckplatz: L3 - Cache
Größe: 16MiB
Kapazität: 16MiB
Takt: 1GHz (1.0ns)
Konfiguration: level=3
*-cpu
Beschreibung: CPU
Produkt: AMD Ryzen 7 PRO 7840U w/ Radeon 780M Graphics
Hersteller: Advanced Micro Devices [AMD]
Physische ID: 3
Bus-Informationen: cpu@0
Version: 25.116.1
Seriennummer: Unknown
Steckplatz: FP8
Größe: 1976MHz
Kapazität: 5447MHz
Breite: 64 bits
Takt: 100MHz
Fähigkeiten: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp x86-64 constant_tsc rep_good amd_lbr_v2 nopl nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba perfmon_v2 ibrs ibpb stibp ibrs_enhanced vmmcall fsgsbase bmi1 avx2 smep bmi2 erms invpcid cqm rdt_a avx512f avx512dq rdseed adx smap avx512ifma clflushopt clwb avx512cd sha_ni avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local avx512_bf16 clzero irperf xsaveerptr rdpru wbnoinvd cppc arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold v_vmsave_vmload vgif x2avic v_spec_ctrl vnmi avx512vbmi umip pku ospke avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq rdpid overflow_recov succor smca fsrm flush_l1d cpufreq
Konfiguration: cores=8 enabledcores=8 microcode=175128836 threads=16
*-memory
Beschreibung: Systemspeicher
Physische ID: 5
Steckplatz: Systemplatine oder Hauptplatine
Größe: 16GiB
*-bank:0
Beschreibung: SODIMM Synchron Unbuffered (Unregistered) 5600 MHz (0,2 ns)
Produkt: HMCG78AGBSA095N
Hersteller: Hynix/Hyundai
Physische ID: 0
Seriennummer: 28F7E155
Steckplatz: Bottom-Slot 1(left)
Größe: 16GiB
Breite: 64 bits
Takt: 1305MHz (0.8ns)
*-bank:1
Beschreibung: Project-Id-Version: lshwReport-Msgid-Bugs-To: FULL NAME EMAIL@ADDRESSPO-Revision-Date: 2012-05-30 08:16+0000Last-Translator: Hendrik Schrieber Language-Team: German de@li.orgMIME-Version: 1.0Content-Type: text/plain; charset=UTF-8Content-Transfer-Encoding: 8bitX-Launchpad-Export-Date: 2024-02-12 11:07+0000X-Generator: Launchpad (build 9643586c585856148a18782148972ae9c1179d06)Project-Id-Version: lshwReport-Msgid-Bugs-To: FULL NAME EMAIL@ADDRESSPO-Revision-Date: 2012-05-30 08:16+0000Last-Translator: Hendrik Schrieber Language-Team: German de@li.orgMIME-Version: 1.0Content-Type: text/plain; charset=UTF-8Content-Transfer-Encoding: 8bitX-Launchpad-Export-Date: 2024-02-12 11:07+0000X-Generator: Launchpad (build 9643586c585856148a18782148972ae9c1179d06) [leer]
Produkt: Unknown
Hersteller: Not Installed
Physische ID: 1
Steckplatz: Bottom-Slot 2(right)
*-firmware
Beschreibung: BIOS
Hersteller: HP
Physische ID: 10
Version: V82 Ver. 01.04.10
date: 03/01/2024
Größe: 64KiB
Kapazität: 32MiB
Fähigkeiten: pci pcmcia upgrade shadowing cdboot bootselect edd int5printscreen int9keyboard int14serial int17printer acpi biosbootspecification netboot uefi
*-pci:0
Beschreibung: Host bridge
Produkt: Advanced Micro Devices, Inc. [AMD]
Hersteller: Advanced Micro Devices, Inc. [AMD]
Physische ID: 100
Bus-Informationen: pci@0000:00:00.0
Version: 00
Breite: 32 bits
Takt: 33MHz
*-generic UNGEFORDERT
Beschreibung: IOMMU
Physische ID: 0.2
Bus-Informationen: pci@0000:00:00.2
Version: 00
Breite: 32 bits
Takt: 33MHz
Fähigkeiten: msi ht bus_master cap_list
Konfiguration: latency=0
*-pci:0
Beschreibung: PCI bridge
Physische ID: 2.2
Bus-Informationen: pci@0000:00:02.2
Version: 00
Breite: 32 bits
Takt: 33MHz
Fähigkeiten: pci pm pciexpress msi ht normal_decode bus_master cap_list
Konfiguration: driver=pcieport
Ressourcen: irq:32 memory:94c00000-94cfffff ioport:2810900000(Größe=1048576)
*-network
Beschreibung: Kabellose Verbindung
Produkt: MEDIATEK Corp.
Hersteller: MEDIATEK Corp.
Physische ID: 0
Bus-Informationen: pci@0000:01:00.0
Logischer Name: wlp1s0
Logischer Name: /dev/fb0
Version: 00
Seriennummer: 00:41:0e:58:b3:bb
Breite: 64 bits
Takt: 33MHz
Fähigkeiten: pciexpress msi pm bus_master cap_list ethernet physical wireless fb
Konfiguration: broadcast=yes depth=32 driver=mt7921e driverversion=6.5.0-35-generic firmware=____000000-20231120183441 ip=192.168.178.35 latency=0 link=yes mode=1920x1200 multicast=yes visual=truecolor wireless=IEEE 802.11 xres=1920 yres=1200
Ressourcen: iomemory:280-27f irq:116 memory:2810900000-28109fffff memory:94c00000-94c07fff
*-pci:1
Physische ID: 2.3
Bus-Informationen: pci@0000:00:02.3
Version: 00
Breite: 32 bits
Takt: 33MHz
Ressourcen: irq:33 memory:94b00000-94bfffff
*-generic
Beschreibung: Wireless controller
Produkt: Intel Corporation
Hersteller: Intel Corporation
Physische ID: 0
Bus-Informationen: pci@0000:02:00.0
Version: 01
Breite: 64 bits
Takt: 33MHz
Fähigkeiten: pm msi pciexpress bus_master cap_list
Konfiguration: driver=iosm latency=0
Ressourcen: irq:79 memory:94b00000-94b00fff memory:94b01000-94b010ff
*-pci:2
Physische ID: 2.4
Bus-Informationen: pci@0000:00:02.4
Version: 00
Breite: 32 bits
Takt: 33MHz
Ressourcen: irq:34 memory:94a00000-94afffff
*-nvme
Beschreibung: NVMe device
Produkt: SAMSUNG MZVL4512HBLU-00BH1
Hersteller: Samsung Electronics Co Ltd
Physische ID: 0
Bus-Informationen: pci@0000:03:00.0
Logischer Name: /dev/nvme0
Version: HPS4NHAV
Seriennummer: S6B5NF0W502823
Breite: 64 bits
Takt: 33MHz
Fähigkeiten: nvme pm pciexpress msix nvm_express bus_master cap_list
Konfiguration: driver=nvme latency=0 nqn=nqn.1994-11.com.samsung:nvme:PM9B1:M.2:S6B5NF0W502823 state=live
Ressourcen: irq:82 memory:94a00000-94a03fff
*-namespace:0
Beschreibung: NVMe disk
Physische ID: 0
Logischer Name: hwmon3
*-namespace:1
Physische ID: 2
Logischer Name: /dev/ng0n1
*-namespace:2
Physische ID: 1
Bus-Informationen: nvme@0:1
Logischer Name: /dev/nvme0n1
Größe: 476GiB (512GB)
Fähigkeiten: gpt-1.00 partitioned partitioned:gpt
Konfiguration: guid=791a07ed-1724-42c1-8a7d-b5cfa36a9903 logicalsectorsize=512 sectorsize=512 wwid=nvme.144d-533642354e463057353032383233-53414d53554e47204d5a564c3435313248424c552d3030424831-00000001
*-volume:0 UNGEFORDERT
Beschreibung: Windows FAT Laufwerk
Hersteller: MSDOS5.0
Physische ID: 1
Bus-Informationen: nvme@0:1,1
Version: FAT32
Seriennummer: 545c-8662
Größe: 95MiB
Kapazität: 99MiB
Fähigkeiten: boot fat initialized
Konfiguration: FATs=2 filesystem=fat name=EFI system partition
*-volume:1
Beschreibung: reserved partition
Hersteller: Windows
Physische ID: 2
Bus-Informationen: nvme@0:1,2
Logischer Name: /dev/nvme0n1p2
Seriennummer: 3effd4cd-911a-41c1-893f-2e0e6817e712
Kapazität: 15MiB
Fähigkeiten: nofs
Konfiguration: name=Microsoft reserved partition
*-volume:2
Beschreibung: Windows NTFS Laufwerk
Hersteller: Windows
Physische ID: 3
Bus-Informationen: nvme@0:1,3
Logischer Name: /dev/nvme0n1p3
Version: 3.1
Seriennummer: d45bab2c-6960-1e44-ba13-6b4b0660880b
Größe: 263GiB
Kapazität: 263GiB
Fähigkeiten: ntfs initialized
Konfiguration: clustersize=4096 created=2024-01-30 13:46:55 filesystem=ntfs name=Basic data partition state=clean
*-volume:3
Hersteller: Windows
Physische ID: 4
Bus-Informationen: nvme@0:1,4
Logischer Name: /dev/nvme0n1p4
Version: 3.1
Seriennummer: 049b-abdd
Größe: 31GiB
Kapazität: 31GiB
Konfiguration: clustersize=4096 created=2024-07-14 10:05:36 filesystem=ntfs label=Shared name=Basic data partition state=clean
*-volume:4
Beschreibung: EXT4-Laufwerk
Hersteller: Linux
Physische ID: 5
Bus-Informationen: nvme@0:1,5
Logischer Name: /dev/nvme0n1p5
Logischer Name: /
Version: 1.0
Seriennummer: 51286104-d581-4067-b342-94c663badf0b
Größe: 180GiB
Fähigkeiten: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
Konfiguration: created=2024-06-28 21:56:50 filesystem=ext4 lastmountpoint=/ modified=2024-08-28 19:53:44 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro mounted=2024-08-28 17:53:44 state=mounted
*-volume:5
Hersteller: Windows
Physische ID: 6
Bus-Informationen: nvme@0:1,6
Logischer Name: /dev/nvme0n1p6
Version: 3.1
Seriennummer: b4f0-b543
Größe: 772MiB
Kapazität: 786MiB
Fähigkeiten: boot ntfs initialized
Konfiguration: clustersize=4096 created=2024-01-30 13:50:45 filesystem=ntfs state=clean
*-pci:3
Physische ID: 3.1
Bus-Informationen: pci@0000:00:03.1
Version: 00
Breite: 32 bits
Takt: 33MHz
Ressourcen: irq:35 ioport:6000(Größe=16384) memory:7c000000-93ffffff ioport:1800000000(Größe=68719476736)
*-pci:4
Physische ID: 4.1
Bus-Informationen: pci@0000:00:04.1
Version: 00
Breite: 32 bits
Takt: 33MHz
Ressourcen: irq:36 ioport:2000(Größe=16384) memory:64000000-7bffffff ioport:800000000(Größe=68719476736)
*-pci
Produkt: JHL7540 Thunderbolt 3 Bridge [Titan Ridge DD 2018]
Physische ID: 0
Bus-Informationen: pci@0000:64:00.0
Version: 06
Breite: 64 bits
Takt: 33MHz
Fähigkeiten: pci pm msi pciexpress normal_decode bus_master cap_list
Ressourcen: iomemory:51210-5120f irq:123 ioport:2000(Größe=16384) memory:64000000-7bffffff ioport:800000000(Größe=68719476736)
*-pci:0
Physische ID: 2
Bus-Informationen: pci@0000:65:02.0
Version: 06
Breite: 32 bits
Takt: 33MHz
Ressourcen: irq:125 ioport:2000(Größe=4096) memory:64000000-640fffff ioport:800000000(Größe=1048576)
*-usb
Beschreibung: USB controller
Produkt: JHL7540 Thunderbolt 3 USB Controller [Titan Ridge DD 2018]
Physische ID: 0
Bus-Informationen: pci@0000:66:00.0
Version: 06
Breite: 32 bits
Takt: 33MHz
Fähigkeiten: pm msi pciexpress xhci bus_master cap_list
Konfiguration: driver=xhci_hcd latency=0
Ressourcen: irq:127 memory:64000000-6400ffff
*-usbhost:0
Produkt: xHCI Host Controller
Hersteller: Linux 6.5.0-35-generic xhci-hcd
Physische ID: 0
Bus-Informationen: usb@9
Logischer Name: usb9
Version: 6.05
Fähigkeiten: usb-2.00
Konfiguration: driver=hub slots=2 speed=480Mbit/s
*-usb
Beschreibung: USB-Hub
Produkt: Dell dock
Hersteller: Dell Inc.
Physische ID: 2
Bus-Informationen: usb@9:2
Version: 1.57
Fähigkeiten: usb-2.10
Konfiguration: driver=hub slots=5 speed=480Mbit/s
*-usb:0
Produkt: Dell dock
Physische ID: 3
Bus-Informationen: usb@9:2.3
Version: 1.22
Konfiguration: driver=hub slots=6 speed=480Mbit/s
*-usb:0
Beschreibung: Tastatur
Produkt: Dell Computer Corp Dell Universal Receiver System Control
Hersteller: Dell Computer Corp
Physische ID: 1
Bus-Informationen: usb@9:2.3.1
Logischer Name: input20
Logischer Name: /dev/input/event16
Logischer Name: input20::capslock
Logischer Name: input20::compose
Logischer Name: input20::kana
Logischer Name: input20::numlock
Logischer Name: input20::scrolllock
Logischer Name: input21
Logischer Name: /dev/input/event17
Logischer Name: /dev/input/mouse2
Logischer Name: input22
Logischer Name: /dev/input/event18
Logischer Name: input23
Logischer Name: /dev/input/event19
Version: 2.28
Fähigkeiten: usb-2.00 usb
Konfiguration: driver=usbhid maxpower=100mA speed=12Mbit/s
*-usb:1
Produkt: USB2.0 Hub
Hersteller: Genesys Logic, Inc.
Physische ID: 2
Bus-Informationen: usb@9:2.3.2
Version: 85.36
Konfiguration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s
*-usb:2
Beschreibung: Maus
Produkt: Microsoft USB Precision Mouse
Hersteller: Microsoft
Physische ID: 3
Bus-Informationen: usb@9:2.3.3
Logischer Name: input24
Logischer Name: /dev/input/event20
Logischer Name: /dev/input/mouse3
Logischer Name: input25
Logischer Name: /dev/input/event21
Logischer Name: input26
Logischer Name: /dev/input/event22
Logischer Name: input27
Logischer Name: /dev/input/event23
Version: 2.16
Fähigkeiten: usb-2.01 usb
Konfiguration: driver=usbhid maxpower=400mA speed=12Mbit/s
*-usb:3
Beschreibung: Audio-Gerät
Produkt: USB Audio
Hersteller: Generic
Physische ID: 4
Bus-Informationen: usb@9:2.3.4
Logischer Name: card2
Logischer Name: /dev/snd/controlC2
Logischer Name: /dev/snd/pcmC2D0c
Logischer Name: /dev/snd/pcmC2D0p
Logischer Name: /dev/snd/pcmC2D1p
Version: 0.01
Seriennummer: 200901010001
Fähigkeiten: usb-2.00 audio-control
Konfiguration: driver=snd-usb-audio maxpower=500mA speed=480Mbit/s
*-usb:4
Beschreibung: Schnittstellengerät (Human interface device)
Produkt: Dell dock
Hersteller: Dell Computer Corp.
Physische ID: 5
Bus-Informationen: usb@9:2.3.5
Version: 1.01
Konfiguration: driver=usbhid maxpower=100mA speed=480Mbit/s
*-usb:1
Produkt: Dell dock
Physische ID: 5
Bus-Informationen: usb@9:2.5
Version: 1.01
*-usbhost:1
Physische ID: 1
Bus-Informationen: usb@10
Logischer Name: usb10
Version: 6.05
Fähigkeiten: usb-3.10
Konfiguration: driver=hub slots=2 speed=10000Mbit/s
*-usb
Produkt: Dell dock
Physische ID: 2
Bus-Informationen: usb@10:2
Version: 1.57
Konfiguration: driver=hub slots=4 speed=10000Mbit/s
*-usb:0
Produkt: Dell dock
Physische ID: 3
Bus-Informationen: usb@10:2.3
Version: 1.22
Konfiguration: driver=hub slots=4 speed=5000Mbit/s
*-usb:1
Beschreibung: Allgemeines USB-Gerät
Produkt: USB 10/100/1000 LAN
Hersteller: Realtek
Physische ID: 4
Bus-Informationen: usb@10:2.4
Version: 31.11
Seriennummer: 111000001
Fähigkeiten: usb-3.00
Konfiguration: driver=r8152 maxpower=288mA speed=5000Mbit/s
*-pci:1
Physische ID: 4
Bus-Informationen: pci@0000:65:04.0
Version: 06
Breite: 32 bits
Takt: 33MHz
Ressourcen: irq:126 ioport:3000(Größe=12288) memory:64100000-7bffffff ioport:800100000(Größe=68718428160)
*-pci:5
Physische ID: 8.1
Bus-Informationen: pci@0000:00:08.1
Version: 00
Breite: 32 bits
Takt: 33MHz
Fähigkeiten: pci pm pciexpress msi normal_decode bus_master cap_list
Ressourcen: irq:37 ioport:1000(Größe=4096) memory:94000000-945fffff ioport:2800000000(Größe=276824064)
sudo lshw 2/2
       *-display
            Beschreibung: VGA compatible controller
            Produkt: Advanced Micro Devices, Inc. [AMD/ATI]
            Hersteller: Advanced Micro Devices, Inc. [AMD/ATI]
            Physische ID: 0
            Bus-Informationen: pci@0000:c4:00.0
            Version: d7
            Breite: 64 bits
            Takt: 33MHz
            Fähigkeiten: pm pciexpress msi msix vga_controller bus_master cap_list fb
            Konfiguration: depth=32 driver=amdgpu latency=0 resolution=1920,1200
            Ressourcen: iomemory:280-27f irq:78 memory:2800000000-280fffffff memory:94000000-941fffff ioport:1000(Größe=256) memory:94500000-9457ffff
       *-multimedia:0
            Beschreibung: Audio device
            Physische ID: 0.1
            Bus-Informationen: pci@0000:c4:00.1
            Logischer Name: card0
            Logischer Name: /dev/snd/controlC0
            Logischer Name: /dev/snd/hwC0D0
            Logischer Name: /dev/snd/pcmC0D3p
            Logischer Name: /dev/snd/pcmC0D7p
            Logischer Name: /dev/snd/pcmC0D8p
            Logischer Name: /dev/snd/pcmC0D9p
            Version: 00
            Breite: 32 bits
            Takt: 33MHz
            Fähigkeiten: pm pciexpress msi bus_master cap_list
            Konfiguration: driver=snd_hda_intel latency=0
            Ressourcen: irq:108 memory:945c8000-945cbfff
          *-input:0
               Produkt: HD-Audio Generic HDMI/DP,pcm=3
               Physische ID: 0
               Logischer Name: input11
               Logischer Name: /dev/input/event7
          *-input:1
               Produkt: HD-Audio Generic HDMI/DP,pcm=7
               Physische ID: 1
               Logischer Name: input12
               Logischer Name: /dev/input/event9
          *-input:2
               Produkt: HD-Audio Generic HDMI/DP,pcm=8
               Physische ID: 2
               Logischer Name: input13
               Logischer Name: /dev/input/event10
          *-input:3
               Produkt: HD-Audio Generic HDMI/DP,pcm=9
               Physische ID: 3
               Logischer Name: input14
               Logischer Name: /dev/input/event11
       *-generic
            Beschreibung: Encryption controller
            Physische ID: 0.2
            Bus-Informationen: pci@0000:c4:00.2
            Version: 00
            Breite: 32 bits
            Takt: 33MHz
            Fähigkeiten: pm pciexpress msi msix bus_master cap_list
            Konfiguration: driver=ccp latency=0
            Ressourcen: irq:104 memory:94400000-944fffff memory:945cc000-945cdfff
       *-usb:0
            Physische ID: 0.3
            Bus-Informationen: pci@0000:c4:00.3
            Version: 00
            Breite: 64 bits
            Takt: 33MHz
            Fähigkeiten: pm pciexpress msi msix xhci bus_master cap_list
            Ressourcen: irq:76 memory:94200000-942fffff
          *-usbhost:0
               Physische ID: 0
               Version: 6.05
             *-usb:0
                  Beschreibung: Bluetooth-Schnittstelle
                  Produkt: Wireless_Device
                  Hersteller: MediaTek Inc.
                  Physische ID: 3
                  Bus-Informationen: usb@1:3
                  Version: 1.00
                  Seriennummer: 000000000
                  Fähigkeiten: usb-2.10 bluetooth
                  Konfiguration: driver=btusb maxpower=100mA speed=480Mbit/s
             *-usb:1 UNGEFORDERT
                  Hersteller: Synaptics, Inc.
                  Physische ID: 4
                  Bus-Informationen: usb@1:4
                  Version: 0.00
                  Seriennummer: 886a0ec74110
                  Konfiguration: maxpower=100mA speed=12Mbit/s
          *-usbhost:1
               Physische ID: 1
               Bus-Informationen: usb@2
               Logischer Name: usb2
               Version: 6.05
       *-usb:1
            Physische ID: 0.4
            Bus-Informationen: pci@0000:c4:00.4
            Version: 00
            Breite: 64 bits
            Takt: 33MHz
            Ressourcen: irq:80 memory:94300000-943fffff
          *-usbhost:0
               Physische ID: 0
               Bus-Informationen: usb@3
               Logischer Name: usb3
               Version: 6.05
               Konfiguration: driver=hub slots=1 speed=480Mbit/s
             *-usb
                  Beschreibung: Video
                  Produkt: HP 5MP Camera
                  Hersteller: DQYGF0A9IHVCXX
                  Physische ID: 1
                  Bus-Informationen: usb@3:1
                  Version: 0.07
                  Konfiguration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
          *-usbhost:1
               Physische ID: 1
               Bus-Informationen: usb@4
               Logischer Name: usb4
               Version: 6.05
               Konfiguration: driver=hub slots=1 speed=10000Mbit/s
       *-multimedia:1
            Beschreibung: Multimedia controller
            Produkt: Raven/Raven2/FireFlight/Renoir Audio Processor
            Physische ID: 0.5
            Bus-Informationen: pci@0000:c4:00.5
            Version: 63
            Breite: 64 bits
            Takt: 33MHz
            Konfiguration: driver=snd_pci_ps latency=0
            Ressourcen: iomemory:280-27f irq:107 memory:94580000-945bffff memory:2810000000-28107fffff
       *-multimedia:2
            Produkt: Family 17h (Models 10h-1fh) HD Audio Controller
            Physische ID: 0.6
            Bus-Informationen: pci@0000:c4:00.6
            Logischer Name: card1
            Logischer Name: /dev/snd/controlC1
            Logischer Name: /dev/snd/hwC1D0
            Logischer Name: /dev/snd/pcmC1D0c
            Logischer Name: /dev/snd/pcmC1D0p
            Version: 00
            Breite: 32 bits
            Takt: 33MHz
            Ressourcen: irq:109 memory:945c0000-945c7fff
          *-input:0
               Produkt: HD-Audio Generic Mic
               Physische ID: 0
               Logischer Name: input18
               Logischer Name: /dev/input/event14
          *-input:1
               Produkt: HD-Audio Generic Headphone
               Physische ID: 1
               Logischer Name: input19
               Logischer Name: /dev/input/event15
    *-pci:6
         Physische ID: 8.2
         Bus-Informationen: pci@0000:00:08.2
         Version: 00
         Breite: 32 bits
         Takt: 33MHz
         Ressourcen: irq:38 memory:94900000-949fffff ioport:2810800000(Größe=1048576)
       *-generic:0 UNGEFORDERT
            Beschreibung: Non-Essential Instrumentation
            Physische ID: 0
            Bus-Informationen: pci@0000:c5:00.0
            Version: 00
            Breite: 32 bits
            Takt: 33MHz
            Fähigkeiten: pm pciexpress msi cap_list
       *-generic:1 UNGEFORDERT
            Beschreibung: Signal processing controller
            Physische ID: 0.1
            Bus-Informationen: pci@0000:c5:00.1
            Version: 00
            Breite: 64 bits
            Takt: 33MHz
            Fähigkeiten: pm pciexpress msi msix cap_list
            Ressourcen: iomemory:280-27f memory:94900000-9497ffff memory:949c0000-949c1fff memory:2810800000-281083ffff memory:94980000-949bffff
    *-pci:7
         Physische ID: 8.3
         Bus-Informationen: pci@0000:00:08.3
         Version: 00
         Breite: 32 bits
         Takt: 33MHz
         Ressourcen: irq:39 memory:94600000-948fffff
            Physische ID: 0
            Bus-Informationen: pci@0000:c6:00.0
            Version: 00
            Breite: 32 bits
            Takt: 33MHz
            Fähigkeiten: pm pciexpress cap_list
       *-usb:0
            Physische ID: 0.3
            Bus-Informationen: pci@0000:c6:00.3
            Version: 00
            Breite: 64 bits
            Takt: 33MHz
            Ressourcen: irq:81 memory:94600000-946fffff
          *-usbhost:0
               Physische ID: 0
               Bus-Informationen: usb@5
               Logischer Name: usb5
               Version: 6.05
          *-usbhost:1
               Physische ID: 1
               Bus-Informationen: usb@6
               Logischer Name: usb6
               Version: 6.05
       *-usb:1
            Physische ID: 0.4
            Bus-Informationen: pci@0000:c6:00.4
            Version: 00
            Breite: 64 bits
            Takt: 33MHz
            Ressourcen: irq:102 memory:94700000-947fffff
          *-usbhost:0
               Physische ID: 0
               Bus-Informationen: usb@7
               Logischer Name: usb7
               Version: 6.05
          *-usbhost:1
               Physische ID: 1
               Bus-Informationen: usb@8
               Logischer Name: usb8
               Version: 6.05
       *-usb:2
            Physische ID: 0.5
            Bus-Informationen: pci@0000:c6:00.5
            Version: 00
            Breite: 64 bits
            Takt: 33MHz
            Fähigkeiten: pm pciexpress msi msix usb4_host_interface bus_master cap_list
            Konfiguration: driver=thunderbolt latency=0
            Ressourcen: irq:41 memory:94800000-9487ffff
       *-usb:3
            Physische ID: 0.6
            Bus-Informationen: pci@0000:c6:00.6
            Version: 00
            Breite: 64 bits
            Takt: 33MHz
            Ressourcen: irq:58 memory:94880000-948fffff
    *-serial
         Beschreibung: SMBus
         Produkt: FCH SMBus Controller
         Physische ID: 14
         Bus-Informationen: pci@0000:00:14.0
         Version: 71
         Breite: 32 bits
         Takt: 66MHz
         Konfiguration: driver=piix4_smbus latency=0
         Ressourcen: irq:0
    *-isa
         Beschreibung: ISA bridge
         Produkt: FCH LPC Bridge
         Physische ID: 14.3
         Bus-Informationen: pci@0000:00:14.3
         Version: 51
         Breite: 32 bits
         Takt: 66MHz
         Fähigkeiten: isa bus_master
       *-pnp00:00
            Produkt: PnP device PNP0b00
            Physische ID: 0
            Fähigkeiten: pnp
            Konfiguration: driver=rtc_cmos
       *-pnp00:01
            Produkt: PnP device PNP0c02
            Physische ID: 1
            Fähigkeiten: pnp
            Konfiguration: driver=system
       *-pnp00:02
            Produkt: PnP device PNP0c01
            Physische ID: 2
            Fähigkeiten: pnp
       *-pnp00:03
            Produkt: PnP device HPQ8002
            Hersteller: Hewlett-Packard Co.
            Physische ID: 3
            Fähigkeiten: pnp
            Konfiguration: driver=i8042 kbd
       *-pnp00:04
            Physische ID: 4
            Fähigkeiten: pnp
       *-pnp00:05
            Physische ID: 5
            Fähigkeiten: pnp
 *-pci:1
      Physische ID: 101
      Bus-Informationen: pci@0000:00:01.0
      Version: 00
      Breite: 32 bits
      Takt: 33MHz
 *-pci:2
      Physische ID: 102
      Bus-Informationen: pci@0000:00:02.0
      Version: 00
      Breite: 32 bits
      Takt: 33MHz
 *-pci:3
      Physische ID: 103
      Bus-Informationen: pci@0000:00:03.0
      Version: 00
      Breite: 32 bits
      Takt: 33MHz
 *-pci:4
      Physische ID: 104
      Bus-Informationen: pci@0000:00:04.0
      Version: 00
      Breite: 32 bits
      Takt: 33MHz
 *-pci:5
      Physische ID: 105
      Bus-Informationen: pci@0000:00:08.0
      Version: 00
      Breite: 32 bits
      Takt: 33MHz
 *-pci:6
      Physische ID: 106
      Bus-Informationen: pci@0000:00:18.0
      Version: 00
      Breite: 32 bits
      Takt: 33MHz
 *-pci:7
      Physische ID: 107
      Bus-Informationen: pci@0000:00:18.1
      Version: 00
      Breite: 32 bits
      Takt: 33MHz
 *-pci:8
      Physische ID: 108
      Bus-Informationen: pci@0000:00:18.2
      Version: 00
      Breite: 32 bits
      Takt: 33MHz
 *-pci:9
      Physische ID: 109
      Bus-Informationen: pci@0000:00:18.3
      Version: 00
      Breite: 32 bits
      Takt: 33MHz
      Konfiguration: driver=k10temp
      Ressourcen: irq:0
 *-pci:10
      Physische ID: 10a
      Bus-Informationen: pci@0000:00:18.4
      Version: 00
      Breite: 32 bits
      Takt: 33MHz
 *-pci:11
      Physische ID: 10b
      Bus-Informationen: pci@0000:00:18.5
      Version: 00
      Breite: 32 bits
      Takt: 33MHz
 *-pci:12
      Physische ID: 10c
      Bus-Informationen: pci@0000:00:18.6
      Version: 00
      Breite: 32 bits
      Takt: 33MHz
 *-pci:13
      Physische ID: 10d
      Bus-Informationen: pci@0000:00:18.7
      Version: 00
      Breite: 32 bits
      Takt: 33MHz
*-battery
Produkt: WP03051XL
Hersteller: 313-2D-37-A
Physische ID: 1
Steckplatz: Primary
Kapazität: 51310mWh
Konfiguration: voltage=11,6V
*-input:0
Produkt: Power Button
Physische ID: 2
Logischer Name: input0
Logischer Name: /dev/input/event0
Fähigkeiten: platform
*-input:1
Produkt: Sleep Button
Physische ID: 3
*-input:2
Produkt: HP WMI hotkeys
Physische ID: 4
Logischer Name: input10
Logischer Name: /dev/input/event6
*-input:3
Produkt: ELAN07A8:00 04F3:31EC Mouse
Physische ID: 5
Logischer Name: input15
Logischer Name: /dev/input/event12
Logischer Name: /dev/input/mouse0
Fähigkeiten: i2c
*-input:4
Produkt: ELAN07A8:00 04F3:31EC Touchpad
Physische ID: 6
Logischer Name: input17
Logischer Name: /dev/input/event13
Logischer Name: /dev/input/mouse1
Fähigkeiten: i2c
*-input:5
Produkt: Lid Switch
Physische ID: 7
*-input:6
Physische ID: 8
Logischer Name: input3
Logischer Name: /dev/input/event3
*-input:7
Produkt: AT Translated Set 2 keyboard
Physische ID: 9
Logischer Name: input4
Logischer Name: /dev/input/event4
Logischer Name: input4::capslock
Logischer Name: input4::numlock
Logischer Name: input4::scrolllock
Fähigkeiten: i8042
*-input:8
Produkt: Video Bus
Physische ID: a
Logischer Name: input5
Logischer Name: /dev/input/event5
*-input:9
Produkt: Wireless hotkeys
Physische ID: b
Logischer Name: input9
Logischer Name: /dev/input/event8
*-network
Beschreibung: Ethernet interface
Physische ID: c
Logischer Name: enx30d0420ff517
Seriennummer: 30:d0:42:0f:f5:17
Größe: 10Mbit/s
Kapazität: 1Gbit/s
Fähigkeiten: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
Konfiguration: autonegotiation=on broadcast=yes driver=r8152 driverversion=v1.12.13 duplex=half firmware=rtl8153b-2 v2 04/27/23 link=no multicast=yes port=MII speed=10Mbit/s
In Windows I can find the following information about it.
Its called NxpNfcClientDriver ACPI\NXP8013
With that information I found the following in Zorin:
ls -l /sys/bus/acpi/devices/NXP8013\:00/
insgesamt 0
-r--r--r-- 1 root root 4096 Aug 28 21:53 adr
-r--r--r-- 1 root root 4096 Aug 28 21:53 hid
-r--r--r-- 1 root root 4096 Aug 28 21:53 modalias
-r--r--r-- 1 root root 4096 Aug 28 21:53 path
lrwxrwxrwx 1 root root    0 Aug 28 21:53 physical_node -> ../../../../platform/AMDI0010:01/i2c-1/i2c-NXP8013:00
drwxr-xr-x 2 root root    0 Aug 28 21:53 power
-r--r--r-- 1 root root 4096 Aug 28 21:53 status
lrwxrwxrwx 1 root root    0 Aug 28  2024 subsystem -> ../../../../../bus/acpi
-rw-r--r-- 1 root root 4096 Aug 28  2024 uevent
-r--r--r-- 1 root root 4096 Aug 28 21:53 uid
Try this tool:
On further searching it looks like it is not supported, remember hardware in general is designed for that other OS, vendors are not honourbound to provide a driver for the Linux kernel!:
" Linux driver for nxpnfcclientdriver acpi\nxp8013
Based on the provided search results, there is no direct mention of a Linux driver for NxpNfcClientDriver ACPI\NXP8013. The search results primarily focus on Windows drivers and downloads.
However, it’s essential to note that NXP Semiconductors provides NFC (Near Field Communication) solutions, and their drivers are typically designed for Windows operating systems. Linux drivers for NXP NFC solutions might not be publicly available or officially supported."
too bad :frowning:
thanks for your assessment!
