I wanted to play some games on my zorin lite computer when I beat it up I saw busy box v1.30.1 so I watch the YouTube tutorial but it didn't work . I need help help I need help
At that BusyBox screen if you type exit and hit the enter key, it should print out what the error is.
Can you enter in exit then relay that result here?
Code 4
First run:
(initramfs) fsck /dev/sda? -y
This may take a few minutes.
NOTE: replace /sda? to your root partition ID.
To see the ID:
lsblk
you will see the root ID there,
sda 8:0 0 232.9G 0 disk ├─sda1 8:1 0 512M 0 part /boot/efi └─sda2 8:2 0 232.4G 0 part / sr0 11:0 1 1024M 0 rom
So my example command would be:
(initramfs) fsck /dev/sda2 -y
Then
(initramfs) reboot
Thank you it now works
