Can I hook up a Logitech Wingman Digital Extreme?
Hey people,
I would like to install some old games and hookup my old, like new, game controllers.
I have a Logitch Wingman joystick and a Force Feedback Steering Wheel with pedals.
I haven't used them since going from windows 7 to 10 because M.$ made the OS incompatible. (They wanted me to spend hundreds of dolars on new hardware)
Can I get these working on 17.2 ?
I am confident this should be Plug n' Play as is.
This one I am less sure about whether it is Plug n' play.
It should generally work, but some features may need libff or ffmpeg (oddly enough) or other configurations included in Proton (available in Steam).
The worst that can happen is they do not work so - plug in and test. IF you run into issues, you can ask in this thread and see if things can get sorted out.
