Grub is a Menu - the Advanced Options should be visible directly below the boot option that simply says Zorin OS
You can take a photo with your cell phone and upload it to the forum if you need.
When I pressed ESC at the start up it was really quick loading words and failure messages and then booted into my desktop
I have also tried connecting to my phone as a hot spot and see if I can download zorin again but no luck.
Also my internet was fine for 2 weeks or so since I installed Zorin and just when I did the Sudo upgrade everything got screwed.
oh.... yeah... no internet...
And you cannot connect with hotspot? Temporarily in order to run the OEM Kernel installation?
I've tried but for some reason it doesn't work.
I mean there is internet it's even connected but I always get the DNS server error on webpages.
I was online this morning
Please connect using hotspot,
then check in terminal if
sudo apt update
works or if it gives 404 errors
I just get error messages. 0%loading and then it's stuck and err 13 so far
I only get the site can't be reached
DNS address could not be found
Ok so I had Timeshift installed a couple of days ago and just went to an old version of my laptop and I'm back online. Oh my god.
You could also have accessed the older kernel during startup .
