Cannot disable or remove top popup dividers, need help, not sure the correct name
I have been using Zorin, good distro but when I put my browser or windowpanel to top this popup dividers drive me crazy, forcing me to divide my screen setup, this is the worst out of all. No name, no way to remove it, no help on it. I mean if I put a coffee on a table and a plate on a table I'd like to put it where ever I want. But Zorin decides to choose where we put out separate window browser, windows panels, where they think it should be. This is impossible to avoid if you have a work setup that you need to move the panels/windows to the top edge. I was going to purchase for agency but have to go towards another distro since they (do not) want to help remove this very annoying feature. Please just one developer please give us the choice to move things where we want on the Zorin OS screen.
Go to Zorin Appearance > Windows
and disable the Advanced window tiling there.
You can also disable the active screen edges in the app Settings > Multitasking.
Thank you, in 18.1 I went to Zorin Appearance>Windows>Advanced Window Tiling setting button> and (Uncheck) the enable snap assistant. Thank you Forpli - your the best.
