Hello,
my HP Laserjet M1132 MFP seems installed correctly, but cannot print anything.
I have installed HPLIP and it recognized the printer and installed it. It is listed in the printer list.
If I start to print I get the message "unable to connect to printer". In the HPLIP panel is "busy - code 1001".
I have already tried to:
- Restart the printer and pc.
- Check the connection between the printer and pc (USB)
- Uninstall and reinstall the printer.
- Set the printer as default.
Any help will be appreciated.
Thank you
gdm59
