I'm having a weird problem and I'm desperate after doing research for almost 4 hours now.
I just purchased a NAS device and it works fine and I've created 2 shared folders (all permissions should be fine on the NAS end as well) and I've been following a guide that says to mount these shares in fstab. Said and done. However, I can NOT change the shares' group, the shares', nor the shares' permissions and it shows as read only (755) and I have no idea WHY!
Here's the entry in fstab for the server (Please disregard the childish name lol)
should imply read AND write permissions, however, chmod 755/775/777 doesn't do ANYTHING. Trying to change the permissions as a system user with Nautilus makes it switch back from "read and write" to "read only" instantly and I'm freaking desperate.
Could anybody point me to the right direction?
Also, this is what I get when I ls -lhs
drwxr-xr-x 2 donatus donatus 0 Aug 25 23:44 8TBSeagateFilme
So no read permissions for me and I need write permissions on that share, as it is for a Plex Media Server and automation programs like Sonarr.
Thank you once again. I did that, still no dice. It seems like there's no way to give execute and write permission to that NAS share Weird thing is (you remember: I'm a noob) when I earlier opened folders as a system user with Nautilus, I was easily able to grant permissions to that folder by just changing the settings. When I now try to change the settings, it wouldn't get applied, instead switching back to "read only" instantly. I'm despereate
Thank you sir Seems like I had cifs utilities installed already, but that's an interesting point!
Could you maybe craft me the path from my bits? I'm too tired to get the variables tonight
What should be the /media part and what the /NAS part?
EDIT: Don't get me wrong btw! I can access the shares from within the file manager on my (Zorin) computer. Just not by other programs that desperately need write privileges So I figured it must have had something to do that it's not properly mounted. Btw the name of the entire NAS is "kleinegeileslut" Or let's say it's the servers' name
I wonder if it would work better without the user/pass and rely on your Home Directory access for the security... It may, but you must decide the essential parts of your security.
Thank you man! I will try that prior to keep fumbling with fstab, as I don't see any way out of my misery at the moment I'll let you know soon how it went
Hey therrre! I did it!!!! It's working! I can't believe it The catch was that - for the NFS share - the mounting path cannot be /share1, but /volume1/share1. After that I was able to mount it through fstab and all worked well. I was able to grant write permissions as easy as an angel in the dark, so all good now on this end
