Can't use an ext mouse on surface pro 5
hi! im trying to install zorin on an old surface pro 5 (one which i unfortunately dont have the keyboard attachment for) and when i boot into the live environment if i plug in my mouse it just doesn't work (i need to use it to select try zorin os and connect the mouse via bluetooth so i can put the boot usb back in and finish the install) also i do know the live environment doesn't get frozen after i remove the boot usb since volume control works just fine
