Hi guys
I have a NTFS partition but... I can't write on...
This is the configuration of partition.... Does anyone have an hint to configure properly the partition?
Thanks
Hi guys
Thanks
Is the partition owned by Windows, or just storage? If storage, try changing ownership of the partition to yourself.
You may ensure that the package needed for reading ntfs is installed (It should be but...)
sudo apt install --reinstall ntfs-3g
It could also be fast boot, as I was told in my question, fast boot prevents disk modifications.
Thanks
problem solved only reinstalling nfps-3g
Thanks a lot
I created a video on how to create an NTFS data partition, separately, before installing ZorinOS:
