I want to cast my phones microphone into pc although i am using audio relay but it has 1 hour time limit.Can any one suggest any app which is simple to use like audio realy but with no time limit
You could check Settings>Audio if the Mic is detected as Input Device. Alternatively, You could check that in Pulse Audio Volume Control - a Program for set up Audio Input and Output. You can install it with sudo apt install pavucontrol in Terminal.
This might be the solution for you:
Brave A.I. search result;
" WO Mic
WO Mic is a specialized software suite that turns a smartphone into a virtual microphone for a PC. Unlike standard Bluetooth pairing, it uses a dedicated client-server architecture to stream audio with minimal latency, making it a popular alternative to KDE Connect for users needing a relay microphone.
Key Features
Virtual Driver Technology : On Windows, it installs a virtual audio driver (e.g.,
womic.sys) that makes the phone appear as a standard recording device in the system. This allows it to work seamlessly with any software (Zoom, OBS, Discord) without complex manual configuration. -
Low Latency : It is designed for near-instant audio transmission. Using a USB cable typically provides the lowest latency and highest audio quality, while Wi-Fi and Bluetooth offer more mobility with slightly higher delay.
Multi-Platform Support : It is available for Android , iOS , Windows , macOS , and Linux .
Connection Methods
USB : Best for stability and quality; requires enabling USB debugging on Android.
Wi-Fi : Requires both devices to be on the same network; involves entering the phone’s IP address into the PC client.
Bluetooth : Uses standard Bluetooth pairing but routes audio through the WO Mic protocol rather than standard A2DP/HFP profiles.
Wi-Fi Direct : Allows connection without an existing router by creating a direct link between the phone and PC.
Alternatives
AudioRelay : Often recommended as a modern alternative with robust support for Linux (Pipewire) and low-latency performance.
KDE Connect : While it lacks native microphone relay, it is preferred for its broader ecosystem of integration (notifications, file transfer) among Linux/Windows users."
