When I open my pc, My pc's sound not worked. So, I went to setting>sound>output and changed output device option analog to line out. Then my pc's sound worked. Every time I had to change my sound setting. I'm using core Zorin OS 16 and there has no dual boot. This is my daily driver.
Thank you so much. It work it !. Zorin os Helping support is awesome. I love it.
Thanks for the update- because this has been a common complaint / request. I have bookmarked this thread for the future when a user runs into this.
First go to setting>sound>output and output device. You have to choose the option which will bring up the sound in the sound box or headphone.
In my case, I'm choosing Line Out - Built-in Audio.
And open the terminal and write this command
pactl list short sinks
Copy the name of the output device that will be the idle output device. In my case, that is first item [alsa_output.pci-0000_00_1b.0.analog-stereo]
Now open Startup Application and click Add.
On the command input write this text
pactl set-default-sink [paste your output device name]
In my case, I'm writting this command
pactl set-default-sink alsa_output.pci-0000_00_1b.0.analog-stereo
Write name as your wish and click Add.
Thanks for writing the detailed walkthrough. This will be very useful for future readers.
Since Aravisian noted the value of this thread, I took the liberty to change the title for easier searching - I hope you don’t mind.
If there is a wish to revert to the original title, please note it is: “Every time when I opened my pc, I need to change sound output setting manually for sound listen from sound box“
It's okey no problem, I'm glad you solved my problem so sincerely. Again thank you
