Hi I am in the middle off swiching full time hopefully to zorin os from Windows
But one thing I can't work out at the moment if I can change how notifications show I often use the brave browser when I get a notification it right in the middle off then screen I like to be to make them show at the bottom or else where so its not so much in the way
I am using the default desktop environment i think
This is an often-asked question, actually. You are asking about the Gnome-Extension that handles on-screen notifications being Centered and large, correct?
hi i guess so as it brave that i use and when using zorin os it smack bag in the middle off the screen when i used windows it was in the bottom right was not as in your way before you closed it down
That is a feature of Gnome-Shell. I do not use Gnome, as I prefer XFCE (Zorin OS Lite).
On mine, notifications are small and placed in the upper right corner of the screen.
On Cinnamon, they are on the Lower right.
I have never really looked into fixing this... Whether it is a Gnome Extension at work or handled by the Shell. I will try looking into it.
You can then activate the extension and use a slider for the horizontal and vertical position of the notifications and place them anywhere you want on the screen. Including right in the middle, if you prefer.
