Becauuuuuuse I can't leave anything alone for more than a few minutes, I decided to change the time server to the time.nist.gov in the U.S. Not having a clue what I was doing I did a world wide search on Ubuntu. In the /etc/systemd/timesyncd.conf file I removed the comment mark and made this change...
It looks like it worked to me...is that the case? Below are my actions, not shown is the edit action of the .conf file.
In the output I see where the vendor preset is enabled. Did my setting over ride this, or is this something else?
If this is correct and will help someone else, the mods can move the thread to the Tutorials section if they want.
thanks
lou@lou-zorin:~$ sudo -i
root@lou-zorin:~# man chmod
root@lou-zorin:~# man chown
root@lou-zorin:~# chown lou /etc/systemd/timesyncd.conf
#edited file at this time and saved, then returned ownership to root
root@lou-zorin:~# chown root /etc/systemd/timesyncd.conf
root@lou-zorin:~# sudo systemctl restart systemd-timesyncd
# looking to see what I may have broken
root@lou-zorin:~# systemctl status systemd-timesyncd
● systemd-timesyncd.service - Network Time Synchronization
Loaded: loaded (/lib/systemd/system/systemd-timesyncd.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2022-10-19 18:45:53 EDT; 1min 32s ago
Docs: man:systemd-timesyncd.service(8)
Main PID: 6414 (systemd-timesyn)
Status: "Initial synchronization to time server 132.163.96.4:123 (time.nist.gov)."
Tasks: 2 (limit: 18772)
Memory: 1.3M
CGroup: /system.slice/systemd-timesyncd.service
└─6414 /lib/systemd/systemd-timesyncd
Oct 19 18:45:53 lou-zorin systemd[1]: Stopping Network Time Synchronization...
Oct 19 18:45:53 lou-zorin systemd[1]: systemd-timesyncd.service: Succeeded.
Oct 19 18:45:53 lou-zorin systemd[1]: Stopped Network Time Synchronization.
Oct 19 18:45:53 lou-zorin systemd[1]: Starting Network Time Synchronization...
Oct 19 18:45:53 lou-zorin systemd[1]: Started Network Time Synchronization.
Oct 19 18:45:53 lou-zorin systemd-timesyncd[6414]: Initial synchronization to time server 132.163.96.4:123 (time.nist.gov).
root@lou-zorin:~#
