Citrix Workspaces does not work on Zorin OS 18 Pro
Good morning everyone. Hope everyone is doing well.
Hoping someone can help with the following.
Issue: I cannot get Citrix Workspaces to start.
OS: Zorin OS 18 Pro
Citrix Workspaces: icaclient_25.08.10.111_amd64.deb
Steps to replicate the issue
  1. Log into Zorin OS
  2. Search for Citrix Workspaces
  3. Click on Citrix Workspaces
  4. Nothing starts
Troubleshooting steps already tried
zorinos@lenovo:~$ sudo apt install -y libva2 libva-drm2 libva-x11-2 net-tools
zorinos@lenovo:~/Downloads$ sudo dpkg -i icaclient_25.08.10.111_amd64.deb
zorinos@lenovo:~/Downloads$ /opt/Citrix/ICAClient/selfservice --icaroot /opt/Citrix/ICAClient/
/opt/Citrix/ICAClient/selfservice: error while loading shared libraries: libwebkit2gtk-4.0.so.37: cannot open shared object file: No such file or directory
or try to run the app using the icon
Logs
[sudo] password for zorinos:
Reading package lists... Done
libva2 is already the newest version (2.20.0-2ubuntu0.1).
libva2 set to manually installed.
libva-drm2 is already the newest version (2.20.0-2ubuntu0.1).
libva-drm2 set to manually installed.
libva-x11-2 is already the newest version (2.20.0-2ubuntu0.1).
libva-x11-2 set to manually installed.
net-tools is already the newest version (2.10-0.1ubuntu4.4).
net-tools set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 61 not upgraded.
zorinos@lenovo:~$ cd Downloads/
zorinos@lenovo:~/Downloads$ ls
(Reading database ... 385978 files and directories currently installed.)
Preparing to unpack icaclient_25.08.10.111_amd64.deb ...
Unpacking icaclient (25.08.10.111) over (25.08.10.111) ...
Setting up icaclient (25.08.10.111) ...
/usr/bin/sudo
Processing triggers for desktop-file-utils (0.27-2build1) ...
Processing triggers for gnome-menus (3.36.0-1.1ubuntu3) ...
Hi and welcome.
Zorin 18 is a fork of Ubuntu 24.04:
" Citrix Workspace 25.08.10 on Ubuntu 24.04 may fail to launch due to missing or incompatible dependencies, particularly related to GTK WebView libraries and libwpe-1.0 , which have been removed or updated in Ubuntu 24.04.
Primary Fix: Symlink Missing GTK WebView Libraries
The core issue is that Citrix Workspace expects older library versions (libwebkit2gtk-4.0.so.37 , libjavascriptcoregtk-4.0.so.18 ) that are no longer present by default in Ubuntu 24.04. These are replaced with libwebkit2gtk-4.1.so.0 and libjavascriptcoregtk-4.1.so.0 .
Solution: Create symbolic links to trick Citrix into using the newer versions:
cd /opt/Citrix/ICAClient/gtk2/lib
sudo ln -s /usr/lib/x86_64-linux-gnu/libwebkit2gtk-4.1.so.0 libwebkit2gtk-4.0.so.37
sudo ln -s /usr/lib/x86_64-linux-gnu/libjavascriptcoregtk-4.1.so.0 libjavascriptcoregtk-4.0.so.18
Additionally, ICU libraries may be missing:
sudo ln -s /usr/lib/x86_64-linux-gnu/libicui18n.so libicui18n.so.70
sudo ln -s /usr/lib/x86_64-linux-gnu/libicuuc.so libicuuc.so.70
sudo ln -s /usr/lib/x86_64-linux-gnu/libicudata.so libicudata.so.70
Alternative Fix: Install from Ubuntu 22.04 (Jammy) Repository
If the symlinks don’t resolve the issue, install libwebkit2gtk-4.0-dev from Ubuntu 22.04 (Jammy) :
sudo add-apt-repository -y "deb http://us.archive.ubuntu.com/ubuntu jammy main"
sudo apt update
sudo apt install libwebkit2gtk-4.0-dev
:warning: Note : Adding old repositories can cause conflicts. Remove them after installation:
sudo add-apt-repository -r "deb http://us.archive.ubuntu.com/ubuntu jammy main"
Troubleshooting Tips
  • Launch from terminal: /opt/Citrix/ICAClient/selfservice to see error messages.
  • Use workspacecheck.sh for dependency checks: /opt/Citrix/ICAClient/util/workspacecheck.sh .
  • Ensure Snap is not interfering — remove snap versions of Citrix if present.
  • For .ica file handling , set default app:
xdg-mime default wfica.desktop application/x-ica
Workaround: Use Citrix Web Portal
If the app still fails, access Citrix via the web browser :
  1. Log in to your Citrix web portal.
  2. Go to Settings > Advanced Settings .
  3. Change preference from "Citrix App" to "Web Browser" .
This bypasses the desktop app entirely and is stable on Ubuntu 24.04.
:white_check_mark: Summary : The most reliable fix is symbolic linking the missing GTK WebView libraries. The web portal is a stable alternative if the app continues to fail.
It seems to want this Package but it isn't available, only libwebkit2gtk-4.1
Is Your donwloaded File the newest Version?
Thank you for the reply and yes, I downloaded the latest .deb file.
Let me try the steps as outlined by swarfendor437 and come back on this thread.
