Well, since you found the answer already, this will be a little bit dated, but that was just Google Chrome there that I installed from the Synaptic package manager, if I remember correctly. Firefox would not highlight the X, interestingly enough.
But, this isn't something I ever would have noticed anyway. I never full screen my applications. I have this stupid habit of having a main window open, usually my browser, and then I'll place new windows in locations where an edge is peaking out from behind the browser so I can click on it to bring it to the front. I'm all about inefficiency!
Yes, you must change the XFWM theme.
Navigate to the Theme you are using, the to XFWM4 directory.
In themerc, change:
button_spacing=0
button_offset=0
Open the Image files for top-right-active top-right-inactive right-active right-inactive
in Gimp.
From image on the menubar, select Canvas Resize and shrink the WIDTH ONLY (make sure to click the UNLINK icon) on each of the above files.
Once done properly, go to File, then down where export "overwrite as..."
When the above is done, it will shrink the right edge up to the corner of the screen.
I am sorry. I have been mostly fronting Gnome issues, especially since Zorin OS 16 was released. I was on auto-pilot when I typed Nautilus.
This is odd... I had tested this on my own copy before making the suggestion, just to be sure it would work.
Let me try testing it again just to see what went wrong...
CSD applications (Gnome apps) will not display the same as the others because Gnome did away with and removed the Window management and titlebars since they decided we don't need them and don't need user control or choice in the matter, either.
You can patch this by using PCMan's gtk3-nocsd package which breaks the gnomish CSD and forces windows to use the proper window manager.
sudo apt install gtk3-nocsd
Must reboot to see the effect.
This will affect all apps run from Home Level, but not root.
In the meantime, let me see what I can do with the Zorin Theme again.
That is happening in Firefox because Firefox was taught by Gnome it has to manage the Window Management since Gnome refuses to do it anymore.
Open Firefox and tell it that it no longer has to.
Click the Hamburger Icon
More Tools>
Customize Toolbar
At the very, very bottom is a checkbox for Titlebar and it should have no check mark on it. Check that to ON. That is the setting for "Use System Title Bars".
That will solve your problem.
No... it's mostly all in one place except... If you are using Snap Packages or Flatpak packages. Anything installed with those will not follow your standard theme.
Zorin does have Flatpak'ed themes - so you may have cases where a flatpak is using that, instead of your system theme.
The best way to know is; check if you see a difference between apps- like the one in Firefox you noted above.
Then check the source of those packages.
