since a while I noticed, that after each login after suspend (not after reboot) the clock in the taskbar is missing. I can correct this with a manual gnome reset (alt + ctrl + r then Enter) but it's a little bit annoying.
Does anybody has an idea what to setup, alter or avoid to make that behavior disappear?
A bit lacking where Gnome-extensions are concerned... I often hope that in posting, it helps steer the thoughts of the other user in a direction that helps them to find a solution.
