In my opinion, when customizing colors, the chosen color should only affect the folder icons and not the entire layout, giving them a subtle tint of light blue, yellow, green, brown, etc.
In any case, this option should be added.
This change would make Zorin more attractive to users than other distros.
I've moved your post to the "Feedback" category so the developers can take this idea into consideration.
Personally, I don't really like that the light gray (in light themes) of the windows blends with the accent color. It would be nice if you could set that separately whether you want it that way or not.
I agree!
Thanks!
It is a common agreement from what I have seen.
For most of us, that it is treated as a full color tint of everything defies what an accent is.
A color accent accentuates the existing pallet, rather than changing it.
Overall, I like the design. What bothers me, though, is that the text is colored as well, which might make it harder to read.
I agree. It's not good!
When resolved this problem?
It's up to the developers whether they decide to implement this suggestion. Not all suggestions and requests that users make in the feedback category will be implemented in future versions or updates of Zorin. After all, preferences often vary. So unfortunately, some of our requests are not taken into consideration.
The Arduin OS personalization is a very beatiful.
