Informações do Hardware e Sistema
- Sistema Operacional: Zorin OS 18 (64-bit)
- Kernel: Linux 6.18.1-generic
- Modelo do Hardware: Positivo C4128A-14
- Placa de Vídeo (GPU): Intel Corporation GeminiLake [UHD Graphics 600]
- Versão do Firmware (BIOS): V1.14.X (Maio/2024)
Uploading: image.png…
Uploading: Captura de tela de 2026-01-14 13-59-43.png…
Can you please describe the bug or issue?
Your screenshot looks like a login screen. I do not see anything far out of the ordinary...
então, o problema é que a tela padrão do zorin os não era essa, pelo menos pra mim
Have you followed any online guides, or added any packages that change the system; Installed KDE, XFCE or another desktop?
Marked your last post as
Solution.
system
Closed
8
