Configurate BCD Menu
I have EaseUS Partition Master and I want to add Zorin OS into my BCD list instead of Zorin OS. How I do that?
Use EasyBCD (the free one) from NeoSmart:
I can't use EasyBCD because my motherboard is EFI mode and Linux Option is disabled on EasyBCD Software
Here you go:
" Edit BCD for Linux
To edit the BCD to accommodate Linux instead of GRUB on an EFI motherboard, you can use the bcdedit command in an Administrator command prompt. The command to set the boot path to the Linux bootloader would be:
bcdedit /set {bootmgr} path \EFI\ubuntu\grubx64.efi
or
bcdedit /set {bootmgr} path \EFI\debian\grubx64.efi
or
bcdedit /set {bootmgr} path \EFI\grub\grubx64.efi
Replace ubuntu , debian , or grub with the appropriate directory name where your Linux bootloader is located. This command changes the default boot entry in the Windows Boot Manager to point to the Linux bootloader. However, this change might need to be reset after each major system update.
Alternatively, you can manually boot into the UEFI menu and select the Linux bootloader file (grubx64.efi) from the EFI file options to boot into Linux."
Courtesy Brave A.I. search engine via mojeek search engine.
