Hi, I install Conky and select a clock widget but it updates without wiping the previous image and just smudges further every second. Any ideas please?
The conky clock rc file should be located in ~.conky directory. Can you paste the conky file contents here using the `</> tags button on the posting toolbar?
# conkyrc_seamod
# Date : 05/02/2012
# Author : SeaJey
# Version : v0.1
# License : Distributed under the terms of GNU GPL version 2 or later
# This version is a modification of conkyrc_lunatico wich is modification of conkyrc_orange
# conkyrc_orange: http://gnome-look.org/content/show.php?content=137503&forumpage=0
# conkyrc_lunatico: http://gnome-look.org/content/show.php?content=142884
background yes
update_interval 1
cpu_avg_samples 1
net_avg_samples 2
temperature_unit celsius
double_buffer yes
no_buffers yes
text_buffer_size 2048
gap_x 40
gap_y 70
minimum_size 300 900
maximum_width 350
own_window yes
own_window_type normal
own_window_transparent yes
own_window_argb_visual yes
own_window_argb_visual no
own_window_colour 000000
own_window_argb_value 0
own_window_hints undecorate,sticky,skip_taskbar,skip_pager,below
border_inner_margin 0
border_outer_margin 0
alignment top_right
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders no
override_utf8_locale yes
use_xft yes
xftfont caviar dreams:size=10
xftalpha 0.5
uppercase no
# Defining colors
default_color FFFFFF
# Shades of Gray
color1 DDDDDD
color2 AAAAAA
color3 888888
# Orange
color4 EF5A29
# Green
color5 77B753
# Loading lua script for drawning rings
lua_load ./seamod_rings.lua
lua_draw_hook_post main
## System information using conky capabilities
# Header with base system info
TEXT
${font Ubuntu:size=10,weight:bold}${color4}SYSTEM ${hr 2}
${offset 15}${font Ubuntu:size=10,weight:normal}${color1}$sysname $kernel
${offset 15}${font Ubuntu:size=10,weight:normal}${color1}$nodename
${offset 15}${font Ubuntu:size=10,weight:normal}${color1}Uptime: $uptime
# Showing CPU Graph
${voffset 20}
${offset 120}${cpugraph 40,183 666666 666666}${voffset -25}
${offset 90}${font Ubuntu:size=10,weight:bold}${color5}CPU
# Showing TOP 5 CPU-consumers
${offset 105}${font Ubuntu:size=10,weight:normal}${color4}${top name 1}${alignr}${top cpu 1}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color1}${top name 2}${alignr}${top cpu 2}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color2}${top name 3}${alignr}${top cpu 3}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color3}${top name 4}${alignr}${top cpu 4}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color3}${top name 5}${alignr}${top cpu 5}%
#Showing memory part with TOP 5
${voffset 40}
${offset 90}${font Ubuntu:size=10,weight:bold}${color5}MEM
${offset 105}${font Ubuntu:size=10,weight:normal}${color4}${top_mem name 1}${alignr}${top_mem mem 1}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color1}${top_mem name 2}${alignr}${top_mem mem 2}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color2}${top_mem name 3}${alignr}${top_mem mem 3}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color3}${top_mem name 4}${alignr}${top_mem mem 4}%
${offset 105}${font Ubuntu:size=10,weight:normal}${color3}${top_mem name 4}${alignr}${top_mem mem 5}%
# Showing disk partitions: root, home and Data
${voffset 28}
${offset 90}${font Ubuntu:size=10,weight:bold}${color5}DISKS
${offset 120}${diskiograph 33,183 666666 666666}${voffset -30}
${voffset 20}
${offset 15}${font Ubuntu:size=9,weight:bold}${color1}Free: ${font Ubuntu:size=9,weight:normal}${fs_free /}${alignr}${font Ubuntu:size=9,weight:bold}Used: ${font Ubuntu:size=9,weight:normal}${fs_used /}
${offset 15}${font Ubuntu:size=9,weight:bold}${color1}Free: ${font Ubuntu:size=9,weight:normal}${fs_free /home}${alignr}${font Ubuntu:size=9,weight:bold}Used: ${font Ubuntu:size=9,weight:normal}${fs_used /home}
${offset 15}${font Ubuntu:size=9,weight:bold}${color1}Free: ${font Ubuntu:size=9,weight:normal}${fs_free /media/Data}${alignr}${font Ubuntu:size=9,weight:bold}Used: ${font Ubuntu:size=9,weight:normal}${fs_used /media/Data}
# Network data (my desktop have only LAN). ETHERNET ring is mostly useless but looks pretty, main info is in the graphs
${voffset 43}
${offset 90}${font Ubuntu:size=10,weight:bold}${color5}ETHERNET
${voffset 40}
${offset 15}${color1}${font Ubuntu:size=9,weight:bold}Up: ${alignr}${font Ubuntu:size=9,weight:normal}$color2${upspeed eth0} / ${totalup}
${offset 15}${upspeedgraph eth0 40,285 4B1B0C FF5C2B 100 -l}
${offset 15}${color1}${font Ubuntu:size=9,weight:bold}Down: ${alignr}${font Ubuntu:size=9,weight:normal}$color2${downspeed eth0} / ${totaldown}
${offset 15}${downspeedgraph eth0 40,285 324D23 77B753 100 -l}
${color4}${hr 2}
This is repeated with conflicting values.
This is repeated with the same values.
I see it has a Lua Script. That may be where the drawing issue is.
Who is the maintainer of this conky? SeaJey? Have you reported this issue on their github?
No, I will do this asap. Thanks.
The conky.rc is also an older syntax style for an earlier version of conky. Some of the older themes run fine in conky manager, but may not work properly or at all if manually installed.
Thanks for that. I’m trying to find widgets I can download and install and just work!
Listen...
I will point out how great Linux is all day long.
But let's be fair and honest. Not everything in Linux is shiny.
Conky is something that generally is not a thing you just download and it works. This is not because it is Broken.
It is because it is something that is User Controlled and Defined. The user must put in the necessary effort.
Yes, as Winged1 points out, the older syntax style is used in your file - but that's ok. The Syntax is backported. Those usually work fine.
An example of Conky Not Working as Downloaded:
The author wrote the script they are using based on their hardware, so their conky that relays netspeed for example is listed at ETH0 because they use Ethernet. You need to change that script by looking at your Wifi ID
ifconfig
changing eth0 to something like wlp1s0 or whatever you see as your ID in the command above.
See what I mean? The author cannot know your hardware. And you must go and look and change it to match.
Some of us on here write conky objects though. So if you have a Design in Mind and Want something, we can help.
I was unlucky with my own themes and had to update the syntax after the release of conky 1.10, but perhaps that's been addressed in newer versions.
thanks for all replies. I've downloaded MX-Conky Widgets etc. which work fine.
