Control C + V doesn't work
Using the new Zorin 18.1....Control C + V doesn't work :((((
  1. How do I fix this?
  2. Why is this not set up by default (this is the sort of thing that puts off potential new linux users)?
Thanks!
Where does it not work? In terminal? There you need ctrl+shift+v or ctrl+shift+c.
Hello and welcome,
It is setup by default, and like @Forpli said it doesn't work on terminal...
So if it doesn't work elsewhere you may have a conflict.
Go n terminal and give us the output of
echo $XDG_SESSION_TYPE
Currently, it doesn't work in any app I've tried it on.
Hi Nourpon, thanks :blush:
The output I get is:
wayland
Try to switch to Xorg:
  • Logout
  • At the login screen, click your username (don't enter password)
  • Click the gear icon in the bottom right
  • Select "Zorin Desktop on Xorg"
  • Log in
an see if it work
im not sure what i have installed maybe nautlias but i have a right click menu for copy paste
We are talking about keyboard here... and no need to install something to have basic function...
Nourpon, thanks! That did it :grinning_face:
That was bugging me soooo much!!
All cool! Thanks guys!
Hopefully yet another nail in the Wayland coffin! (Long live XLibre! :winking_face_with_tongue:)
