hello! recently i have switched from windows to zorin, is there a way to control my fan speed like I used to do it on my windows!
laptop: asus tuf series!
This may be something you're looking for:
https://extensions.gnome.org/extension/841/freon/
woah!! thx bud, It sounds amazing! gonna try it asap. and yeah I thought maybe fn + f5 can chage it, but was never sure about it!
yeah showing the icon while toggling would be awesome. if you got any solution for that, it'll be happy to know it as well. ![]()
