Copy Fail not fixed in 6.17
The Copy Fail vulnerability (CVE-2026-31431) is fixed in the following Linux kernel versions:
7.0
6.19.12
6.18.22
6.12.85
6.6.137
6.1.170
5.15.204
5.10.254
Take a look here:
Ubuntu goes the Way with disabling the Module. An Update is theoretically available but because of the current Server Issues difficult to get. I had the Luck to already get it. Look here:
You could manually create the File what is neccessary. Might not be the best Method but at least, You would have it.
Take a look at:
I forgot something: You could disable the Launchpad Sources, then update the System and then enable them again. Could work to get the Update, too.
