Copyq installed but not running
Installed (the excellent) Copyq from the software app in Zorin. It ran once. Now if I hit the Super key the icon for Copyq appears - I hit 'enter' but nothing happens. It doesn't run.
Tried reinstalling via terminal and got the message 'copyq is already the newest version (10.0.0~jammy).'
Still unable to get Copyq to run.
Any advice or recommendations welcome. Thanks.
OS: Zorin OS 17.3 x86_64
Host: 20KES09E07 ThinkPad X280
Kernel: 6.8.0-59-generic
Uptime: 30 mins
Packages: 1970 (dpkg), 20 (flatpak)
Shell: bash 5.1.16
Resolution: 1366x768
DE: GNOME 43.9
WM: Mutter
WM Theme: ZorinOrange-Dark
Theme: ZorinOrange-Dark [GTK2/3]
Icons: ZorinOrange-Dark [GTK2/3]
Terminal: gnome-terminal
CPU: Intel i5-7300U (4) @ 3.500GHz
GPU: Intel HD Graphics 620
Memory: 3561MiB / 7690MiB
Fixed partially by running
sudo add-apt-repository ppa:hluk/copyq
sudo apt update
And also adjusting the version in the Zorin starter dialogue to 'Zorin.'
One small problem. I have assigned the shortcut of <ctrl+0> to open the main copyq window. That doesn't work. Otherwise I'll mark this as solved.
