Cosmictron full theme for Cosmic DE has been released! This includes icon themes, wallpaper and color files. 8 different colors are available. All made by me with Inkscape and a text editor app.
Nice. Is that the official COSMIC icon? It has a certain resemblance to Gnome, doesn't it? ![]()
By the way, not to be too picky about it, but there's a gap in the corner and the window. I haven't tested it, I'm just saying based on the screenshot.
I noticed that too, hopefully they will fixed it the gap.
Nice work! For sure the quantity of 800+ icons sounds great. Like, I want to try it soon.
Is or will your Zorin run on COSMIC instead of GNOME?
I'm not sure you can install Cosmic DE on Zorin OS.
You cannot install Cosmic on Zorin - at least not now.
Really awesome! I love that there are 8 different color options β itβs super nice to be able to switch things up depending on your mood. Makes it way more fun to play around with and keeps the desktop looking fresh.
Thanks
If people install "Cosmic Tweak" they can save all the color files into the system.
Yeah, I understand that the System76 the company behind COSMIC plans (=hopes) to replace GNOME or KDE and others in the long run.
Right now, it is the DE for their own distro POP!_OS (also still in beta-modus) and a couple of others.
When it is released and should be based on Ubuntu 24 and Zorin 18 with Ubuntu 24 Base is released, You could theoretically try to add the Cosmic Sources to Zorin and then install Cosmic. But this would be an Experiment what You should try on Your Daily Driver when You need it.
And of course the Zorin Design wouldn't run then because it is for Gome. Or ... maybe @Storm makes Cosmic Versions of the Zorin Themes? Who knows ...
Version 1.1 is out via github.
Changes
Games: (Steam) Immortal Realms - Vampire Wars,
Games: (Steam) Railroads and Catacombs,
Added: Beekeeper Studio, Qgis, PDFarranger,
Added: Xemu, PeaZip, Deluge,
Version 1.2 is out! (got requests).
Games: (Steam) Oaken,
Games: (Steam) Oxygen not Included,
Added: Ark, Filen, Tuta Mail, Jitsi,
On my Cosmic desktop icon theme only works on dock..Folder icons are not shown..is this a bug in icon theme or in Cosmic. Since theme is build for cosmic it is wierd..or am i doing somethig wrong? I copyed folder to .local/share/icons..Cosmic is seeing icon pack, but it looks uncomplete. And i did log out/in ..please help
The latest cosmic DE update altered the structure completely of icon themes, which broke all my themes ![]()
Although a login logout is needed before the system sees the change.
Okay, here's a quick fix. In the theme folder delete folder 16 and symbolic in Places folder of the theme. That should fix it.
Thank you so much!!..
i did some manual adjustment for icons that were missing due to 16 folder removal. So icon set is now complete, thank you again..this is a great icon set..
Better late than never.
Version 1.2.1 is out!
It fixes the folder icon issues.
