If you want to have a bootable USB drive (stick) so that people you meet can try it out on their own (Win) computer, how do you create a bootable USB stick with Zorin (Zorin-OS-18-Core-64-bit-r3.iso) from Zorin, i.e. using Zorin to get it done?
The guides I find when searching seem to be about creating a bootable USB stick from Windows.
Anyone know a link to a suitable guide? Or would like to give a quick step by step guide here?
You need a Tool what works on Zorin. You have a couple of Options:
Impression
Ventoy
Popsicle
Gnome MultiWriter
Fedora Media Writer
to name some of them. I use on Zorin the Tool Impression and it works well for me. Except from Ventoy, they work more or less the same. You choose a Drive and the ISO and the Tool creates the Bootstick.
Ventoy goes a different Way. You install Ventoy on the USB Stick and then, You only have to move the ISO on the Stick; that's it. And You can have several ISO's on the Stick, not only one. So, when You want present several Distro's, You only need one Stick.
