Current using Zorin 18.1 Pro -- issues and suggestions
I keep getting Brave locked up and the OS intervening because Brave is not responding. This happens at a minimum on new pages. And now, as I type this, Brave keeps flashing the bar on top which interrupts my typing.
You REALLY need to add the Mint Driver Manager utility especially for us techies that don't trust what the OS does. I had no idea what driver was in use and no idea if it was the proprietary driver or the ■■■■■■ open source one. Give me a vehicle to see what driver is installed as well as what drivers are available to install via a GUI.
When I click on the Z it seems to provide a mix of installed and uninstalled applications. If I'm wrong, then you REALLY overinstalled things creating a buttload of bloat.
It would be nice for installed applications, if I right click on them, there should be an option for Uninstall.
Steam shows the window as login occurs. Once done it minimizes and once minimized I cannot get the window open again.
You can uninstall apps in the Software center.
The available drivers are shown in the app Software&Updates at the tab Additional drivers.
Try to disable the hardware acceleration in Brave browser. If you can't launch brave browser normally, launch it from terminal and then disable the hardware acceleration in the browser settings.
brave-browser --disable-gpu
Is Steam installed as Flatpak or .deb Version?
