I try to change the position of the notification, but still the preview in the top left, and i can't get the default theme.
Can you please run
sudo apt install --reinstall xfce4-notifyd
Set theme from Retro to Default.
Test position using the Show Preview button.
not working,I have tried a lot of calendar app like osmo , korgnizer , and gcalcli, I have deleted all because i think them may still effect on that
That is a good point... This issue can be caused by a different notification service running. Try using SysMon or Task Manager to check.
I found the problem was because of i3 package which i installed it and removed it in the past, but still something related to it doesn't removed called dunst, so i search it on synaptic and removed it, it is very good now , thank for that page
